Scotties Pinky
The main assemblies have been put together so now the external details can be fitted. Just a warning its still very pink.
The Jerry cans are a mix of Royal model. PE and scratch.
The rear luggage shelf is again a mix of Royal models and scratched detail.
Finally a little bling for the back. The weld detail around the fuel tanks was improved.
cheers
ScottieComment
Evening all, a little bit more done. The 24V slave socket was scratched and added. This was to allow another vehicle to provide electric in the case of flat batteries. These sockets were a standard fit on 'A' vehicles i.e. Armoured or HGV systems. Most Land rovers were 12V but vehicles FFR ( Fitted For Radio) were 24V to allow for the Radio equipment. This also meant that if you could lay your hands on one you could fit a BV (boiling vessel) these were great for boiling your water and heating your tins.
next up was the radio set. This is a mix of resin, etch and a lot of scratch. Fitted to the radio is a handset and cable made from 0.3mm copper wire. The base station cable is also made from 0.5 copper wire. I also decided to make a bog standard Army right angle torch. This will all be painted prior to fitting.
cheers
ScottieComment
Scottie,
PINK!!!!! oh my aching eyes.... Now having to type this from 5 foot away using a long stick with a nail in the end....
Do love all the extra work you are putting into this build, and as always the details are superb.
Mike.Comment
After my very brief foray into wings, I have returned to normality. This was a bargain for £9.50 delivered evil bay win. As you can see it is the Italeri 1/35 SAS Pink panther. The vehicle was based on the long wheel base landrover.
The box has the Revell style end opening box. It contains 4 vivid pink sprues that are showing their age. But this is how I like my kits, plenty of opportunity to tweak. And as usual I have picked up some aftermarket etch.
[ATTACH=CONFIG]n1195358[/ATTACH]
[ATTACH=CONFIG]n1195359[/ATTACH]
[ATTACH=CONFIG]n1195360[/ATTACH]
Hope you can join me along the way. One question for you all any idea what Pink I should use?
cheers
ScottieComment
Thanks Andy.
Andrew, cheers mate.
Doug, it certainly won't be as pink as the plastic that's for sure.Comment
