Thanks Mick, should be going on with the paint in the next day or so.....got the last bits on this earlier today so when the glue sets the paint will happen.:thumb2:
We'll see Lee, right now I'm thinking about my next build for the diorama. It will be a Phanomen Granit 25H ambulance. Maybe I'll cook up a batch when I start that build thread. :thumb2:
Well here is the last update before paint flies......wipers installed, added rear license plate with a tail light stem, added the tow hitch, drilled out the headlight buckets for lenses and as a final touch, I bent the front axle to give the appearance of the wheels turned slightly to the left.....just to add interest on the diorama........oops, just noticed I need to install the driver's side mirror.
Well here is the last update before paint flies......wipers installed, added rear license plate with a tail light stem, added the tow hitch, drilled out the headlight buckets for lenses and as a final touch, I bent the front axle to give the appearance of the wheels turned slightly to the left.....just to add interest on the diorama........oops, just noticed I need to install the driver's side mirror.[ATTACH=CONFIG]n1199403[/ATTACH][ATTACH=CONFIG]n1199404[/ATTACH][ATTACH=CONFIG]n1199405[/ATTACH]
Rick
That's coming on very nicely! Looking forward to the paint!
Thanks Guys, just finished cleaning the A/B.....all went according to plan. I love working with Enamel paint, properly thinned it covers fantastic and smooths right out. Never a tip clog or any spitting. :smiling:
