Rick's 1-87 Scale Luftwaffe Airfield Fuel Tanker
    It’s cleaning the remainder out of the airbrush that I dislike about spraying enamels.
    • Mini Me
      • Jun 2018
      • 10711
      #47
      Hi Jakko, I use Lacquer thinner to spray through, then block the tip with cloth to create back wash thru the body back into the siphon bottle numerous times, reversing direction of flow and changing out for clean thinner, till it runs clear. Takes about 5-10 min. Probably been a t least 6 mos. since I last took the A/B to pieces for a scrubbing.
      • scottie3158
        • 14201
        • Holbeach
        #48
        Rick,
        lovely work mate looking forward to the paint.
        • Mini Me
          • Jun 2018
          • 10711
          #49
          Thanks Scottie.....soon as it's dry I'll get a post up with it sat in its wheels....I like to give it at least 24 hrs. Just to be sure I don't finger print myself on it
            Originally posted by Mini Me
            till it runs clear.
            Yeah, that part never works well for me — I spray cleaner through the airbrush, rinse out the cup etc., repeat both until the stuff that comes out is clear, and next time it’s still a 50/50 chance whether it will spray properly. And that’s with acrylics.
            • Mini Me
              • Jun 2018
              • 10711
              #51
              I get that Jakko, acrylics, if I'm not mistaken, are based on synthetic products that don't break down the same way enamel, or solvent based products do. I'm not sure what auto manufacturers use now , but back in the day it was all lacquer or enamel based paint. I bought this A/B over 40 years ago and have only sprayed enamel paint through it.....seems to work ok
              • Mini Me
                • Jun 2018
                • 10711
                #52
                As promised, here are a couple of pics. with the grey on and I couldn't help spinning the wheels on my moto tool and applying the tire color.....easy peasy! that little blob of putty will be dry soon and I'll repaint the top and it's all detail and weathering from here on. Oops, missed a seam line at the tanks rt. rear....will fix that also.Click image for larger version
ID:	1199491Click image for larger version
                • Mini Me
                  • Jun 2018
                  • 10711
                  #53
                  This is by no means finished but I just wanted to post up the detail painting and weather progress so far.....will not get a chance to later as otherwise occupied. Pete Lowe loaned me one of his helpers to get this crate finished up Click image for larger version
ID:	1199561Click image for larger version
ID:	1199562Click image for larger version
                  • Mark1
                    • Apr 2021
                    • 4156
                    #54
                    Just caught up with this Rick, looking great . :thumb2:
                    • Andy T
                      • Apr 2021
                      • 3239
                      #55
                      Cracking stuff Rick, and now we know your secret of working at this scale :smiling5:
                      • JR
                        • May 2015
                        • 18273
                        #56
                        :nerd: :thumb2::smiling:Nice Rick .
                        • Mini Me
                          • Jun 2018
                          • 10711
                          #57
                          Thanks Folks, I let the cat out 'O the bag by leaving that little yellow "dude" to waltz around while I was taking pics...should have shooed him off to hang with the rest of his pals up on my tool box. Glad you guys are liking the progress so far. Should have this pretty well finished up in another day or so. Then it is on to the dreaded (but Cleanest) resin kit of the Phanomen Granit 25H Ambulance. Gonna be a bit of a challenge with lots of modifications......stay tuned. :thumb2:
                          • Mini Me
                            • Jun 2018
                            • 10711
                            #58
                            Here's a teaser, you can see the rest of the pics. in the completed softskin section. Thanks for helping me push this along, just one step closed to getting the diorama across the finish line.Click image for larger version
