Rick's 1-87 Scale Luftwaffe Phanomen Granit 25H Ambulance
  • Andy T
    • Apr 2021
    • 3239
    #61
    Lovely neat work again Rick.
    I can't imagine how small that hitch pin is! One of those where you can't breathe for fear of blowing it off the bench :smiling5:
    • Mini Me
      • Jun 2018
      • 10711
      #62
      Hi Andy, I suppose it is pretty small, I made it from a piece of .010 brass rod. By comparison, it's twice as big as the .004 stainless steel rod I used to make the vane sight on my Tiger II awhile back ..... All good fun! Thanks for stopping by.:thumb2:
      • Mini Me
        • Jun 2018
        • 10711
        #63
        Not much to show for progress. The rear doors are all but finished I just need to make a window crank for the right hand door....apparently it was a functional window. I also made a false floor out of styrene for the back of this vehicle so I can build the stretcher rack and the bench that sits opposite of it for the stretcher bearers/Medics. This way I will be able to detail paint everything after it is assembled and not have to try masking it all off for the inside/outside final paint on the body. I can just glue it in place after final painting and lower the body down over it once the glue has set.....the logistics of this build are proving to be quite formidable.....Click image for larger version
        • scottie3158
          • 14201
          • Holbeach
          #64
          Great work mate I would struggle with this detail in a bigger scale.
          • JR
            • May 2015
            • 18273
            #65
            Agree with Paul , except I couldn't cope with the detail at that scale .
            Truly amazing Rick .
            • Mini Me
              • Jun 2018
              • 10711
              #66
              Thanks Guys, I wish it was a little neater, but once I get it covered in white paint, most of it will disappear anyway.
              • JR
                • May 2015
                • 18273
                #67
                Don't think you could get it any neater Rick, a marvel you can even see it yet alone do what you have .
                • Mini Me
                  • Jun 2018
                  • 10711
                  #68
                  Well thanks JR....I will admit though I have been struggling with this little bugger. What makes it so interesting is the fact that there is a wealth of photo references on this particular vehicle so there are more than the usual detail shots available.....if I see 'em I gotta make 'em! :thumb2: :nerd:
                    • 15686
                    A few have commented on the neatness of your work and I will certainly go along with that. You have a real ability to work at this ridiculous scale :thumb2:
                    • Mini Me
                      • Jun 2018
                      • 10711
                      #70
                      Thanks for making me LAFF Jim........I couldn't have sed it better!! :tears-of-joy: :tears-of-joy: :tears-of-joy: :thumb2:
                      • Mini Me
                        • Jun 2018
                        • 10711
                        #71
                        A little more from the "ridiculous scale" modeler :tears-of-joy: The original vehicle, as you can see in the photo (for ref. only) has a roof rack on it as well as narrowly spaced boards to help support the load carried on it. I knew I couldn't stick this together with CA as it set so quickly that I would never get these things evenly spaced at .010 of an inch, so I cut a proper width sheet of .005 thick sheet styrene and went to work with my liquid cement and scale 1x3" boards using a razor blade with the edge knocked off it as a spacer. I weighted it down overnight to get a good bond and today I hand lapped it on a surface plate until you could see the boards through the sheet stock they were glued to. Once again, placement is critical so I used 5 min epoxy to stick 'em down to the roof.
                        The railing will be installed just before the paint stage, to keep me from knocking the flimsy little thing off.Click image for larger version
ID:	1200653Click image for larger version
                        • scottie3158
                          • 14201
                          • Holbeach
                          #72
                          Excellent!
                          • JayCee
                            • Aug 2019
                            • 1132
                            #73
                            Insanity ! That's the only way to describe it, but bloody good.
                            John.
                            • Mini Me
                              • Jun 2018
                              • 10711
                              #74
                              Thanks Scottie, I've done all the easy stuff, now I have to figure the best way to represent the interior of this little crate.
                              • Mini Me
                                • Jun 2018
                                • 10711
                                #75
                                I agree John, it is nuts, I guess that's what makes it fun!
