Clyno Vickers Motorcycle Machine Gun Combination 1/32 Scale
  • outrunner
    • Apr 2019
    • 2420
    #61
    Lovely looking outfit that.
    Andy.
    • stillp
      • 8093
      • Pete
      • Rugby
      #62
      Originally posted by Andy the Sheep
      About the hooter: what's the use of a hooter when you have a Vickers...! Did James Bond have a hooter on his Aston Martins? :tongue-out3:
      The hooter doesn't run out of ammo.
      • Neil Merryweather
        • Dec 2018
        • 5185
        • London
        #63
        I think it’s ready for the wet stuff!
        I noticed that the upright bar holding the water box over the sidecar mudguard was too high so I cut it down- but by too much (DOH!), so I had to make a new one from brass rod.
        I repositioned the tripod and pinned it so I can keep the gun separate for painting. It didn’t really affect the angle of the gun so I just cut down the elevation screw.
        I added a couple of fine wires to support the spare wheel. There should be some kind of clamp for it attached to the mudguard rack but life’s too short. There probably should be mudguard stays as well but they’ll be hidden by the spare wheel. Looking at the rack again I think I’ve set it too high, but it will have to stay.
        So the final challenge was the groundsheet under the open front of the sidecar. I had 3 attempts at it, using first tissue paper and then clingfilm, but I reverted to tissue paper which I have impregnated with Superphatic glue(very thin PVA). I’m hoping it will come off for painting, but if it doesn’t I will have to make a version 4….
        I think I have misinterpreted the references by adding the bundle behind the sidecar wheel- I think that is the groundsheet folded up and stowed, because you don’t see both in the same picture DOH! But it’s stuck now and I wanted the one in situ.
        I’m keeping the sidecar separate for painting too, and handling it all has been a complete and utter BEATCH! I broke off both of the PE pedals and lost one to the carpet monster, so I have stuck the remaining one on the outside where it can be seen, and hopefully the lack of the inner one will be hidden.
        The shovel is from the 1/35 ICM set of WWI British Infantry.
        Lastly came the 3D printed ammo box and belt, which are stuck with PVA for now but will also be painted separately.
        So all I have to do now is paint it.
        .....and make a crew, but that will have to wait.
        Thanks for watching
        Neil
          That is looking really good, despite not being the easiest to build (but which resin kit is?).
          • Steve Brodie
            • Sep 2014
            • 4652
            #65
            That is Bl00dy AMAZING WORK on what is a dogs pile of oop: of a kit, if you fancy making another set of wheels and other 3D printed bits, i would very kindly exchange some 'green backs' for a set :smiling2::smiling2:
            • Scratchbuilder
              • Jul 2022
              • 2689
              #66
              Neil,
              Got to the end of your build, and really enjoyed your build of a difficult model.
              Wheels, fantastic result with the 3D printer.
              Vickers, I took the cowards way out and went to Gaspatch for mine, ok they are for aircraft but are so much better detailed.
              Joining the sidecar to the bike frame. You got it spot on, look at the front cover of the instruction manual, it shows it as clear as day.
              Main frame/engine etc, I agree it could have been less busy.
              Once again a big well done to you.
              And as Steve above said, you could actually repay your materials by offering sets of wheels, horn, Vickers as an upgrade. Because I am sure there are lots of frustrated Clyno builders out there who have been stopped by the wheel problem - I for one.
              Mike.
              • Neil Merryweather
                • Dec 2018
                • 5185
                • London
                #67
                Wow thank you Steve that's a great compliment, and food for thought.....
                • Neil Merryweather
                  • Dec 2018
                  • 5185
                  • London
                  #68
                  Neil,
                  Mike.
                  Blimey Mike that is praise indeed, coming from such a God of Scratchbuilding as yourself!
                  I'm rather gobsmacked, actually, Thank you
                  • Neil Merryweather
                    • Dec 2018
                    • 5185
                    • London
                    #69
                    Well, I've done it!
                    And in spite of the aggro I quite enjoyed the experience, although I'm not sure I would do another one immediately, even if I didn't have a backlog building up!
                    Technically it's not a difficult kit, there isn't a huge number of tiny parts (although there are some) but it wasn't easy because it's not clear from the instructions exactly where anything is supposed to fit. I spent most of my time trying to figure out where something should go. Hopefully most of the pitfalls have already been pointed out, but I WOULD recommend leaving off the Ammo boxes (red stripy things) at the rear of the sidecar for painting separately. I assumed they were structural but they are not, and they are IMPOSSIBLE to paint in situ. I am glad I left all the bits separate that I did, too.
                    I was originally planning to try out chipping but I chickened out.
                    It was difficult to find out exactly what colour to use so I went with the nearest thing I already had to the photos I could find,(Russian green 3BO for those who care), and BS Dark Green for the gun.
                    So here it is, for better or worse- especially the photography....
ID:	1204903Click image for larger version
ID:	1204904Click image for larger version
ID:	1204905Click image for larger version
ID:	1204906Click image for larger version
ID:	1204907Click image for larger version
ID:	1204908Click image for larger version
ID:	1204909Click image for larger version
ID:	1204910Click image for larger version
ID:	1204911Click image for larger version
                    and a couple of shots with the rider
ID:	1204913Click image for larger version
ID:	1204914Click image for larger version
ID:	1204915Click image for larger version
                    At least with only three wheels there's no problem getting them all touching the ground!
                    There will be a crew eventually, but I really must get back to the nineteenth century after this.
                    Thanks everyone for watching and being interested- this will be the last from me for a week or so as I am off to LA.
                    Neil
                    PS
                    I am REALLY pleased with the wheels!
                    • Neil Merryweather
                      • Dec 2018
                      • 5185
                      • London
                      #70
                      oops! forgot to paint the number plate.....
                        • 15686
                        That is a real stunner Neil. Superb modelling.
                        • Allen Dewire
                          • 4741
                          • Allen
                          • Bamberg
                          #72
                          Most excellent work Mr. Merryweather!!! All the probs, poor destructions and wonderful etch parts didn't stop you from achieving a fantastic result Neil!!! Love it!!! Have fun on the beach and see you when you get back Sir...
                          Allen
                          • outrunner
                            • Apr 2019
                            • 2420
                            #73
                            Great job with what looks to be a fragile model, well done.
                            Andy.
                            • Andy T
                              • Apr 2021
                              • 3239
                              #74
                              Bloomin' lovely that!
                              It may have been a battle but I'd say you've won it convincingly.
                              • Valeron
                                • Jan 2022
                                • 931
                                • Mike
                                • St Albans
                                #75
                                Brilliant Neil. I haven't really been following the blog but have just read it all.
                                It looked very fiddly.
                                The end result is really good. Great paint job and weathering.
                                Well done
                                Mike
