Quickie: DM 53 APFSDS projectile in 1:12 scale
    On another forum, a group build that ran until today had the theme of “movement”: build a military subject so that it gives the impression of motion. I wanted to join but had no real idea what to do with that in a way that wouldn’t take ages, but eventually got the idea for a modern tank gun projectile while it’s in the air — hoe much more movement could you want?
    After finding some photos and drawings, I decided on 1:12 scale because that meant I could build it around a length of 2 mm rod:
    [ATTACH]484146[/ATTACH]
    The nose cone is from a 1:35 scale tank gun round, the wire is copper and the fins are 0.25 mm plastic card. The whole thing is fitted to a length of 0.4 mm spring steel wire as a stand.
    But this isn’t movement, so I took a Games Workshop “biker” base and glued plastic card over the top:
    [ATTACH]484147[/ATTACH]
    Followed by semi-random pieces of plastic strip:
    [ATTACH]484148[/ATTACH][ATTACH]484149[/ATTACH]
    Once the glue had dried, I cut and filed the overhanging parts to conform to the base shape and painted everything:
    [ATTACH]484150[/ATTACH][ATTACH]484151[/ATTACH][ATTACH]484152[/ATTACH]
    The projectile is silver with Tamiya Smoke over it, then matt black for the nose and tail. The base is an earth brown with some sand-coloured areas (deliberately not covering well), then a layer of Army Painter Soft Tone for shadows and a quick drybrush with sand; that done I painted two bits of strip green, added a wash of Army Painter Green Tone and a yellow-green drybrush, and finished
  • scottie3158
    • 14180
    • Holbeach
    Jakko,
    Looks good but if you could mimic the sabbot leaving the round that would really make to look like it was moving.
    cheers
    Scottie
      • 15595
      Very clever Jakko :thumb2:
        That was my first idea, yes. But I don’t see how I could make three sabot pieces without a lot of work — and that would turn this from a quick-and-dirty, “cool idea, let’s do this” type of model into a very involved one. Well, 3D printing would do the trick, but then I might as well have used that for the projectile too.
