A large & interesting build, I didn't even know you could get this kind of thing Simon. The 'rings' on the real shell base look like it's been turned on a lathe, which given there is a threaded hole for the percussion cap is probably what it is.
SimonT - Pig Models 1:1 88mm Pzgr.39 (APCBC) L/56
I'm still trying to figure out how you are going to etch that swastika into the center of the wreath. Not to mention the WaA number that goes under it. I checked some of my ordnance and you definitely have an inspectors WaA eagle and not a Proof mark. I'm looking forward to seeing how the finish on the shell casing comes out. Rick H.Comment
Thanks Steven
Jakko - hopefully they will look the part. I used my Olfa compass cutter but turned the blade upside down so that it was scribing with the thicker non blade end. Just a couple of light rotations then rub with scotch pad to remove burrs and blend the edgesComment
I'm glad to see you weren't too heavy handed making the machine marks on your case head. The Germans weren't desperate enough at that point in the war to speed up their production and were still putting a good finish to their war materials. If one compares the deep grooves in Steve's case of 1943 to the one I have, mfg. in 1936, there is a considerable difference in the quality of work. Looks to me Mr. T that you are about "spot on". Rick H.Comment
