Waltzer Build
  • Dwayne
    • Nov 2020
    • 49
    #16
    So just for an update I have managed to print a few of the sections although the cold is playing havoc on bed adhesion, I may bring the printer into the house for the rest.
    I have removed the motor to help me get this all lined up. As you can see I did not bother to make different pieces for the sections without a car as there will be wooden platforms on top of each of these which will cover the bearing hole anayway. Some of you may think I have placed the terminal block there for scale but no these are what I am using to fix the wheels in place. The sections are printed with a space for the brass bit of the blocks so I am just stripping the brass from the origional plastic. The metal rods are cleaned up bit of fencing wires which will be painted.
    • Mini Me
      • Jun 2018
      • 10711
      #17
      Hi Dwayne, so if I am looking at this correctly, it appears that the pinwheel was revised and also the platform carriers as well.....a much simpler design although the car bearings seem a tad large for the relative size if the model......how large or what scale is this, by the way? Looking forward to your next installment. Rick H. :thumb2:
      • Dwayne
        • Nov 2020
        • 49
        #18
        The bearing are 4mm id and I have drawn up the cars with a void in order to put some weight into them although early tests with the prototype car above are promising it revolves round in the bearings quite easily even without any added weight, I am expecting the weight to be a matter of fine tuning to get the right amount of spin. As with the carousel I built before I am not working to any specific plans just making it up as I go along which means I cant be sure of scale but the finished size I am expecting is 350mm with the rotating platform being 270mm each of the cars have around a 60mm swing.
        • Mini Me
          • Jun 2018
          • 10711
          #19
          Amazing.........I'm really enjoying this. Hope to see more in the near future. Rick H.
          • stillp
            • 8087
            • Pete
            • Rugby
            #20
            Originally posted by Dwayne
            [ATTACH=CONFIG]n1139071[/ATTACH]
            This makes me think of the plate inside a microwave oven.
            • adt70hk
              • Sep 2019
              • 10400
              #21
              Quite simply brilliant!
              • Dwayne
                • Nov 2020
                • 49
                #22
                Happy New Year Everyone,
                I have not been able to make very much progress on the waltzer due to other things requiring my attention including converting a bike to electric pedal assist for my daughter (later fixing said electric power assist bike when somebody pulled out on her, she is fine but bike needed attention) making a pigrrl hand held game thing again for my daughter and other stuff for myself and others.
                Aaanyway during the time I have managed to print off most of the platform carriers and tonight I printed the first carriage
                I am really pleased with it. As you can see it has a void in the seat which I put there to add weight but I am thinking it wont be needed the carriage seems to move quite easily without any extra weight so I will hold off making any more until I can test it to see if it will spin as it is and if it does I can alter the design to get rid of the void. I know this looks boring at the moment but keep in mind that it will all be painted.
                • Neil Merryweather
                  • Dec 2018
                  • 5182
                  • London
                  #23
                  Now that is some serious CAD engineering,Dwayne.
                  what software do you use and which 3D printer do you have?
                  • Dwayne
                    • Nov 2020
                    • 49
                    #24
                    Hi Neil I am using freecad, I did dabble with fusion360 for a while but found that freecad is easier for me to use. Some find it harder but I guess that has a lot to do with how each person is used to working. Currently I have a cloned prusa i3 printer but thats part of the distraction I was on about above I started to make an enclosure for it as the cold weather plays havoc with bed adhesion and I got so far and thought that it could be a good corexy printer on its own, so I am getting bits together to make it into one now.
                    • adt70hk
                      • Sep 2019
                      • 10400
                      #25
                      Wow!
                      • Neil Merryweather
                        • Dec 2018
                        • 5182
                        • London
                        #26
                        Cheers Dwayne-you certainly make it work for you. I use expensive Magics software at work but I have an eye on retirement so I'm looking for something affordable. I will check out Freecad.
                        I've been spoilt by work - I use the Ultimaker, which comes with the enclosure- but at several times the price of the Prusa!
                        What is the bed on the Prusa? Ultimaker is glass and we use Dimafix .....but this link says delivery to the uk Is not possible grrr. What I like is that it releases as the bed cools down. Let's hope someone imports it before I run out
                        Elegoo is quite good.
                        thanks
                        Neeil
                        • Dwayne
                          • Nov 2020
                          • 49
                          #27
                          thanks
                          Neeil
                          The i3 has a glass bed too and I have to say I had never heard of Dimafix I first tried the gluestick that shipped with the printer but soon turned to TRESemme (not sure how to get the thing above the "e") extra hold hairspray :tears-of-joy: other hairsprays I have tried do not do half as well as that one and it has a quite pleasant smell when you spray it on the hot bed. My printer is in the rather drafty shed so while we are in winter I am having to run the bed hot to keep the prints from lifting.
                          • Neil Merryweather
                            • Dec 2018
                            • 5182
                            • London
                            #28
                            I can see why you would want an enclosure-it will make quite a difference
