Eduard 1/48 FW 190 D-11
    Right chaps & chapess
    I've had this one off & on the bench for yonks, and I'm stuck! The kit was a pig to build & because of the time I've taken, some bits have disappeared; the D/F loop, Morane aerial, drop tank holder thingy ...
    So my question is ... is it worth continuing & displaying? I've got an idea for a little dio
    Any thoughts and/or suggestions will be gratefully received
    Patrick
    • 22769
    That looks great Patrick even with the bits missing ( can't you see if some members have the bits you need or scratch some ) it's well worth putting into a display of some sort.
      Of course it's worth continuing as you have already displayed it here.
      You've done some great work with this that I can see.
      And I'm with Ian above.
      • yak face
        • Jun 2009
        • 13824
        • Tony
        Definitely worth continuing Patrick , it looks fantastic. The missing bits can easily be scratched (well ,not sure about the 'thingy' !) The aerial can be made from plastic strip sanded to an aerofoil shape with a bit of stretched sprue for the whippy end bit and the DF loop can be made by cutting a section of the right diameter drinking straw , readily available from most fast food or coffe shops ( McDs here we come ! mines a choc chip frappe please) , cheers tony
          Looks great to me, and yes, I would display it. You may know stuff is missing, but unless the only people looking at it are modeling pros, the missing stuff will probably go, well... unnoticed.
          • stona
            • Jul 2008
            • 9889
            I think it looks good and I'd display it!
            If it bothers you surely a DF loop and Morane antenna could be easily scratch built. I know of four photos in which various portions of this aircraft are visible and I don't think it had an ETC rack fitted at JV 44. None of the other known 'Doras' at the unit did. Why would they as they only flew patrols over the airfield to cover the jets?
            What werknummer do the decals give? I've only ever seen it assigned to the 220??? block.
              Patrick, your models always show a high level of skill, (higher than mine will probably ever be!)
              Im still amazed that you show that plane, saying its not up to your standard, yet id eat a monkeys Testicle to acheive something like that. And i mean that!
              As evryone else has said, if you cant scratch build the parts (which i believe you can) then surely someone will have some spares. Try Hannants.com as they sell odd bits.
