Thanks to John at the SM shop ive just received my rivetting tool. Ive been wanting a proper one of these for a while now and for around a fiver its a good buy ,plus you get Johns excellent quick service too. Ive used it on a build I'm doing in the background (ie. I havent done a thread for it) . The kit is the excellent monogram F100d super sabre , a lovely kit but one that is lacking in panel line detail in one vital area-- the tail section . This is the one area I'm hoping to emphasise with a heat stained effect typical of the aircraft. The problem was the section was pretty smooth , but the heat staining has a distinctive banded effect between the lines of rivets so I decided to add these in this area to make it look better and to define where to apply the heat staining. Heres the pics of the before (smooth and fairly featureless ) and after rivetting . What do you think , will it be visible enough after a coat of varnish and a wash ? all comments welcome , cheers tony
first time with Rivetting tool
Great looking work Tony and very nice looking rivot detail.
I've only tried mine once with the j10 but still not finished. I have to admit it's a very nice tool but you defo need a steady hand when your doing a straight line
Regards
Robert -
Mine rescued my Phantom, they also come in useful on large decals for removing air pockets
AdrianComment
Good edge guide for tools like this or scribing Is Dymo label tape. Will stick around curves or can be hand held and is thick enough to give a good edge to guide the tool.Comment
Originally posted by \Looks quality buddy which tool did you use if you dont mind me askingComment
Riveting is not one of my favourite pastimes, but that looks to have come out well.
As well as some kind of guide, like Dymo tape, I find I have to concentrate on keeping the wheel and handle in line so that I am working everything in straight lines. Exactly the same applies to scribing.
SteveComment
Originally posted by \That looks really good Tony, I guess you're aiming for something like this on the Super Sabre?
[ATTACH]152613[/ATTACH]Comment
Originally posted by \Is this the Super Sabre from Midland Air Museum at Coventry? It looks familiar.Comment
