My first test piece with airbrush
  • peterairfix
    • Jul 2012
    • 11069
    This is my first test a real air brushing use a test aircraft that I always use before the real thing so I just need some opinion on the bits I have tried.
    I have had a go at persuading and the mottled German camouflage help and advice much appreciated[ATTACH]280712[/ATTACH] [ATTACH]280713[/ATTACH]
  • eddiesolo
    • Jul 2013
    • 11193
    Look okay to me Peter, the preshading looks good although maybe a tad heavy. The mottling looks okay, just small burst and build up as needed.
    Poor ME110
    • col68
      • 1505
      Peter what size needle do you have in airbrush ?
        Looks like the pressure needs reducing a little.
        • peterairfix
          • Jul 2012
          • 11069
          It has a 0.3 needle
          • peterairfix
            • Jul 2012
            • 11069
            Thanks as I am tinned air for the moment so it will take a bit of time to sort myself out
            • eddiesolo
              • Jul 2013
              • 11193
              Is it a compressor or in a can? If it is in a can the flow rate and control is more difficult.
              • peterairfix
                • Jul 2012
                • 11069
                I am currently on tinned air but I do have a compressor lined up its just finding the time to go and get it
                • col68
                  • 1505
                  It has a 0.3 needle
                  Peter trying moving the airbrush closer to the kit I normally keep mine within 1-2 inches.
