A Wall......
  • spanner570
    • 15381
    A Wall......
    Trying to get back to some sense of normality, I've just had a go at making a rather old and rustic red brick stretcher bond wall section.
    I've used thin polystyrene, on which I've used a sharp pencil, a steel rule, and varied the shades using children's acrylics. I've let the paint gather on the brick faces to simulate the clay bake.
    I've included a figure to see what you think of the brickwork scale size.
    Any thoughts folks?.....or can I go into production!
    [ATTACH]292570[/ATTACH]
    Cheers all, and onwards and upwards into 2018!
    Ron
  • Peej
    • Aug 2014
    • 919
    Looks alright to me Ron. Production it is!!!!!!
    • col68
      • 1505
      Looks good to me Ron. I use a similar technique with foam board and once bricks are painted I mix buff acrylic with filler and brush it on as a sludge wash then once you wipe it off you should have all the joints grouted.
      • stillp
        • 8087
        • Pete
        • Rugby
        Looks good to me!
        • spanner570
          • 15381
          Thanks for the input boys.
          I guess it passes muster - Well near enough anyway.........:thumb2:
