Cockpit detail
  • Ancientmariner
    • Feb 2018
    • 859
    Cockpit detail
    Hi all, after a lot of air brushing I wanted to use hand and brush and get a bit of time at it.
    Dug out a 1/32 F-14 with cockpit detailing set and started off. Nice working on something big as I have never done a 1/32 kit before.
    Back seat area is almost done but I'm wondering how to add colour to control panels without making it look like dabbed on paint if that makes sense?
    Any feedback and tips to improve are appreciated.
    • 18882
    Hi James. If you are talking about painting the raised switches etc, I would use the side of the brush rather than the tip. You will get more control that way.
    • Ancientmariner
      • Feb 2018
      • 859
      Thanks Tim...
        • 18882
        Looks good James, glad the tip worked for you.
        • Mr Bowcat
          SMF OG
          • Dec 2016
          • 4593
          • Bob
          • London
          A top tip I was given for demarcation lines between the various panels is to use a clay based wash (white or grey). It can be brushed over the entire pane, and when dry removed from the switch areas with a damp cotton bud. Being a clay wash it comes right off.
          Si vis pacem, para bellum.
          • BarryW
            • Jul 2011
            • 6009
            For knobs and switches I find paint pens are ideal. The brand I use are Posca and they have some good colours.
            • Ancientmariner
              • Feb 2018
              • 859
              Thanks for that Barry, I shall have a look into it.
              • colin m
                • 8738
                • Colin
                • Stafford, UK
                I find that standard colours, straight out of the bottle are too bright. I dull red, yellow and white down a touch with a bit of grey. For applying, I normally use my all purpose needle.
