I have recently just completed the Airfix 1:72 Supermarine Spitfire Mk. Vc and was hoping that you lovely people could give it a once over and give me any feedback.
To put this into context, I joined this forum in January. Before then I completed a couple of Airfix starter kits during the first lockdown using just the 3 or 4 paints and glue supplied. Prior to that I did make models back in the 1970s as a child but these were very basic and knocked up in a matter of hours so we could play with them.
Since joining the forum I have started a couple of blogs but always struggled to complete anything as I’ve been trying to use new techniques which I’ve read about but never used. Anything other than using Humbrol glue and a few Humbrol of paints was new to me.
Modelling has always interested me but time was never on my side to take up the hobby and I’ve been really impressed with builds I’ve seen on this site.
So with this model, I did the following:
Anyway, that’s the story of what I did. The pictures are below.
I really enjoyed it and am looking forward to my next build and getting betters.
Any comments on my build would be appreciated. I can take it so be honest. What could I have done better, differently and what kind of weathering would be good for a model of this scale.
- Gave the sprues a good soak in warm soapy water and dried them
- Build up the cockpit and pilot first, painting 100% with Vallejo model colour paints.
- I assembled the aircraft using a combination of Tamiya, Tamiya extra thin and Micro Crystal clear
- Assembly was pretty straightforward although I couldn’t get the wings 100% correct.
- Also I didn’t fully read the instructions and I build the plane (made a cut) which prevented me from having the cockpit open (there is a closed and open option). This was a shame after adding the detail to the cockpit but a lesson for the future.
- I covered up the cockpit with some damp tissue and primed the aircraft using Tamiya grey primer from a rattle can.
- I then hand painted the plane using Vallejo model colour paints. I thinned these with tap water and the plaint flowed very smoothly. I did 2-3 coats of each colour. I tried to match the Humbrol to Vallejo paints but wasn’t as successful as I’d have liked to be but having authentic colours at this point in the hobby wasn’t a priority.
- I did try masking but unfortunately the masking started to remove small parts of paint down to the primer so I stopped this. I did leave the paint to dry overnight before masking. Maybe that wasn’t long enough.
- Once painted, I applied 2 fine coats of gloss varnish from a rattle can – Rust-oleum – Clear Gloss Finish
- I then added the decals using Vallejo decal fix and softener. Adding the decals was very time consuming. I wish I’d practised more and not gone straight into the large ones on the top of the wings.
- I then applied 2 more fine coats of the same gloss varnish
- I then applied a panel wash using Vallejo Blacks wash, placed it into the panel lines and once dried there, did a general wash on the plane. I’m not really sure what I achieved here as it was all alien to me.
I didn’t find that the wash flowed at all like I’ve seen in some blogs. I did look at Vallejo videos though as these washes seem to be applied more generally over the panel lines and cleaned up with water and airbrush thinner.
- I decided not to proceed with any further weathering and seal the model with a matt coat of Rust-oleum – Clear Matt Finish.
- I also opted out of adding an antenna line. I wasn’t brave enough.
- I also added the cockpit canopy. I had previously painted this but didn’t use masking.
