Intro images
  • Flip
    • Jul 2022
    • 257
    • John
    • Speyside
    Intro images
    This post is merely by way of introduction to other users on the site, and specifically at the request of adt70hk.
    One is of the Dominie T.1 by Airfix. I came across a paint scheme different to that in the kit (different nose) and opted for that.
    Otherwise it is a straight kit build. No AM parts, no weathering or washes.Click image for larger version
    The other is the Airfix starter kit for the Harrier GR.1. Same thing: straight kit build. No AM parts, no weathering or washes.
    Apologies for the layout - I can't work out how to get the right photo with the correct text!
    I don't know how I ended up with joins on the Dominie engines - they did not seem to be apparent after priming.
    The Harrier lost its nose pin early in life :rolling:
    So I replaced it with one of my wife's sewing pins (cut the head off) and Araldited it in place.
    I'd welcome a set of critique-al eyes on these; most especially as I plan to do the Jetstream in the same colour scheme as the Dominie.
    Regards,
    • 22769
    Welcome John, both are very nice builds.
    • Steven000
      • Aug 2018
      • 2822
      • Steven
      • Belgium
      Nice models John, welcome :thumb2:
        • 18261
        Nice little builds.
        The problem with the join on the Dom could be due to over cautious use of glue. That is you didn't use enough. lol
        Nice paintwork on both but especially the Harriet.
          • 15641
          Two very nice models John.
          • outrunner
            • Apr 2019
            • 2420
            Good lookers both of them.
            Andy.
            • adt70hk
              • Sep 2019
              • 10400
              Very nicely done John!!
              Well done.
              • Geoffers
                • Jan 2017
                • 1680
                • Geoff
                Nice work John and welcome :thumb2:
                Geoff.
                • boatman
                  • Nov 2018
                  • 14449
                  • christopher
                  • NORFOLK UK
                  WELL i cant see any probs with the dominie looks great to me always loved this jet
                  chrisbmtb
                  • Code no 10
                    • Jun 2022
                    • 130
                    Nice camo paintjob on the Jump Jet, John. The rocket pods really give the jet presence
                    • Flip
                      • Jul 2022
                      • 257
                      • John
                      • Speyside
                      Wow! Thank you. That was my first time trying that. Hope to get neater by using washes, for example.
                      Kind regards,
                      • Gern
                        • 9209
                        I think Ian's right about those seams. If you don't get cement all the way along a seam, there will always be a gap between the two parts which won't have fused together. No amount of sanding will get rid of it, and I suspect a lot of putties will be too thick to fill what is a really tiny gap.
                        If you use Extra Thin cement, it's worth running the brush the whole length of the seam and not rely too much on capillary action. Don't worry too much about extra cement along the joint line. 90% of the time this will be invisible under your first coat of paint/primer. If it does show through, a light going over with a sponge type sander will shift it.
                        • The Smythe Meister
                          • Jan 2019
                          • 6248
                          Love the Harrier especially
                          A superb Aircraft and you've certainly made an excellent job of that one mate !!
                          Andy
                          • JR
                            • May 2015
                            • 18273
                            Welcome John .
                            • Flip
                              • Jul 2022
                              • 257
                              • John
                              • Speyside
                              Love the Harrier especially :smiling3:
                              Andy
                              Andy,
                              That’s very kind.
                              Thanks
