I know most of the Tamiya 1/32 aircraft usually have "extras" because they are planning a later release of a different variant at some future time. It allows them to utilize the same general sprues and only create new molds for the main parts such as wings or fuselage
Parts left over?
Originally posted by \In all my years I have never had a kit that has had spare parts of any thing. I have wished that there was.
Parts that are not used in the version in the box are often crossed of the instruction sheet, if that is there is a picture of all the sprues...
The model is already painted and varnished and so I am not sure if I can glue them on to varnish successfully. Do you think super glue would do the trick? Cheers. Keith.Comment
I would say in this instance super dooper glue will be fine.
Best with this stuff is to go sparing. a small amount will go off quicker than a big dollop. Careful as you are relying on the varnish and the paint films below holding the pieces.
Happened to me and I always take a view first as adding bits left off some times trying to add them on to the finished article can make them conspicuous. I tend towards leaving them off if they are not essential to the looks.
LaurieComment
Thanks Laurie. I will super glue the parts on, having first painted them. As it happens I bought the glue only this morning because if you remember I broke a leg off the Lunar Lander a couple of weeks back. The leg has gone back just fine. Almost finished! What a learning curve it has been! I must have made every mistake in the book, but at least I have learned a lot from it and all in a short period of time. Looking at buying the Space Shuttle now, to be followed by Concorde. I have definitely got the bug. Cheers. Keith.Comment
Originally posted by \having first painted them
Yes the first lot is learning curve as I still remember well. Deeply frustrating temper raising. But all comes well with a few more under your belt learning all the time and the tips techniques imparted on this forum are phenomenal. You think you have cracked a technique then something new appears to improve matters.
LaurieComment
Originally posted by \Keith.I tend to paint when the small bits and pieces are glued into position with superglue. Then any bits and the joint can be covered with careful painting making a neater join
LaurieComment
