Using the correct filler
    I have picked up my Space Shuttle again after a few weeks off from modelling and need some advice. There is a distinct gap where the wing joins the fuselage and I am not sure what to fill it with. So far I have only had small dents and gaps to fill that were no problem for Mr. Surfacer but this is too big for that.
    Any recommendations please?
    Cheers, Keith[ATTACH]109051.IPB[/ATTACH]
    • 18266
    Which fillers do you have. Silly to suggest one you do not own.
    I would suggest squadron green or good old Humbrol filler. If you have painted, you will need to remove the paint first as both of these will eat you paint. ...
      Okay, thanks for that, the only filler I have is Mr. Surfacer. I haven't painted it yet, knew not to do that.
        If you have any plastic card Keith or an odd unused bit from a sprue or slice a piece of sprue to fill the joint using a poly cement etc. That fills the joint you can then use Mr surfacer 500 to make good the joint.
        Advantage here is you will not get a crack as all the parts are plastic welded together. Used this a number of times and works well. If you do use it I have found it best to put in the cement first followed by the plastic slip filler.
          Thanks Laurie, sounds a good idea. Cheers. Keith.
          • flyjoe180
            • Jan 2012
            • 12390
            • Joe
            • Earth
            Yes, using spacers/filler plastic helps to make the join stronger as well as making the filling job easier. I'm going to use spacers for my B-17 wings to eliminate excessive dihedral.
              Shouldn't you be talking to a doctor about that?
              • aaron
                • Oct 2011
                • 2019
                I can recommend mr dissolved putty as a staple and tamiya putty also. I get more use from Mr dissolved but tamiya is great for the big stuff both can be put over acrylic paint and feathers beautifully.
                  Thanks guys, much appreciated.
                  • flyjoe180
                    • Jan 2012
                    • 12390
                    • Joe
                    • Earth
                    I'm not the one with the gap in my Shuttle.
                      Touché!
