Another glue question...
    Apologies if this has been covered before, but I can't seem to find a thread relating to this.
    I'm trying to modify some of the vinyl (? ) figures from the Airfix RAF Personnel set for use as crew in my Lanc build, which involves some cutting and shutting.
    Can anyone recommend a suitable adhesive to help me put the poor dismembered blighters back together???
    Thanks in advance.
    Cheers, Neil
    Neil do you really mean vinyl figures. Plastic and resin are usual.
    • flyjoe180
      • Jan 2012
      • 12390
      • Joe
      • Earth
      Vinyl or polythene is correct for these Airfix figures Laurie. Revell do plastic figures if you wanted an alternative.
      Neil, check this out http://www.plasticsoldierreview.com/ShowFeature.aspx?id=44
      Many discussions around about Airfix's persistence in moulding their figures out of soft, chemically inert material. It's 2015, not 1960.
        That is interesting info.
        On Superglue I have tried numerous types and amazingly they all differ. Loctite I have found the best so did Which although they only tested about 6 some I have not heard of.
        B & Q do their range. I would consider for your job their Power Flex which is a gel. Unless your joins are perfectly flat. The gel just takes up a bit of unevenness.. Found it is a good idea to use a conditioner before applying the SG as it provides a more secure joint.
          Thanks for the info guys, very helpful. I tried some regular Locktite superglue, with no luck.
          Forgive my ignorance, Laurie, but what do you mean by conditioner???
            Hi Neil. Various names are used. The one I have is Powerdrop Conditioning Pen. Primer activator.
            Has a felt applicator which you rub oer the area to be glued. Wait for it to evaporate then apply glue. It helps to send the glue off and make a sound joint.
            Also have an accelerator which is a liquid. Apply after the joint is made and the superglue will cure immediately. Does tend to leave a white mark so best to test first.
              Ah, I understand. Thanks for the info, Laurie, appreciate it
              Cheers, Neil
