Removing graphics from Diecast models
    Can anybody recommend a brand/type of nail varnish remover suitable for removing graphics from Oxford Diecast models? The brand i use for EFE/Corgi models tend to remove the paint as well.
    Any advice would be appreciated. Cheers.
    Regards Mick.
  • rickoshea52
    • Dec 2011
    • 4076
    • Rick
    Regards Mick.
    Have you tried T cut? I use it to remove printed graphics from model railway locomotives. A dab on a cotton bud is best with gentle rubbing so as not to go throught the base colour to bare metal. I sometimes mask to protect the surrounding area. You are left with a shiny spot where the graphic was so a touch up with varnish will be needed to blend everything back together.
      Thanks for your response mate.
      Have tried this before, with limited success.
      Cheers.
      Regards Mick
        • 18271
        If they are regular waterslide decals you might have luck with a decal solvant such as microSol.
        House hold vinegar might work as well.
