I've used Revell contacta for years.Ive got into the habit of putting the cap on straight after using it .So it doesn't get blocked.On the occasions I forget I push a length of thin wire down the tube to clear it
I don't bother with them. I have some syringes with .2 needle attachments, I decant the glue into the syringe, and use it to apply glue. Works really well, ultra fine application, and no mess or blocked needles.
