breathing masks
  • tanktrack
    • Jun 2012
    • 1429
    breathing masks
    Do you guys wear masks when using glues ie Tamiya green top as I am finding it is irritating my throat when using it up close , I do wear a mask when working with resin or air spraying , I just wondered about glues ?
    Hi Steve.
    If it irritates your throat,wear a mask.
    And make sure your area is well ventilated.
    Ralph.
      I think Steve if it affects you I would wear a mask. But not any old mask. Manufacturers of
      the trade masks have different filters for a number of different things.
      Another thought. Tamiya is very much pear drop smell. Mr Cement S has a different smell
      altogether. Perhaps try that about £4 a bottle much cheaper than a custom filter mask.
      Mr Cement S does the same trick but is a bit faster acting than Tamiya.
      • stona
        • Jul 2008
        • 9889
        I don't but if you are having problems it may well be worth trying another glue. Compositions and solvents vary.
        Steve.
