Micro sol ??
    Micro sol ??
    Hi does anyone have opinions of micro set, sol and liquid decal film. I have never used any of them as I relied on other methods but I think I may give them a go. It is especially of interest if anyone can explain the different functions of each.
    Thanks
    Winker
  • Tom Rigg
    • Apr 2015
    • 101
    Neil,
    There's plenty of tutorials posted for Microsol and Microset.
    They basically soften the decals making application over uneven surfaces easier and then 'fixing' them into that shape (and can aid in the removal of old decals).
    Try having a look at this thread:
    Ok, so I've been reading around a few other websites and a few threads on here and there seems to be a fair bit of reference to microsol and micro set. I understand that they're used to make your details go better but what exactly are they and how do you use them? And more to the point,is it wort...
    All the best
    Tom
      Tom's exactly right Neil. Microset is designed to be applied to the model on the place where a decal should go to prepare the surface. Microsol softens the decal so that it conforms to the surface features; panel lines, zimmerit, nuts & bolts etc.
      However, nothing beats a good,clean, glossy surface when applying any decals. Get that right & most of the potential pitfalls will be avoided.
        Hi Neil ive recently started using Micro Sol and Set and cant fault either. They are easy to use too. Before I used Humbrol Decal Fix but found this very aggresive on acrylic painted surfaces even with a clear coat applied over the paint.
        Stick with Sol and Set you cant go far wrong in my opinion.
        • BarryW
          • Jul 2011
          • 6029
          You also mentioned Micro liquid decal film.  You use this with old or fragile decals.  You paint a couple of coats over the decals before cutting them out to help hold them together while applying them.  It does work OK for all but the worse decals.  Personally I prefer to throw poor, fragile decals such as those from Trumpeter and get paint masks or aftermarket decals instead.
          • tanktrack
            • Jun 2012
            • 1429
            I have just bought micro sol blue/red to try after using vallejo decal fix for years to give it a try .
            • PaulTRose
              • Jun 2013
              • 6487
              • Tattooine
              its good stuff, wouldnt be without it
              Per Ardua
                Thanks to all. I do a gloss coat to put them on but some of the cheaper and older kits are suffering. Thought I'd try something else to see if I can cure it.
                I have noticed a particular problem with silvering and non adhering on italeri kits.
