Hi guys I'm just getting back into modeling and getting a airbrush for my new build. My question is the new pledge klear multi surface still good for cockpits and gloss coats cheers grant
Klear
I'll have to disagree with Ian there Grant. Whilst the new Pledge stuff is ok for dipping canopies, it's nowhere near as good as the old Klear for applying gloss coats IMHO. I find the current product needs too many coats to give a good gloss, which can mean you loose fine detail.
Personally I prefer Humbrol Clear.Comment
CheersComment
To be honest Alan, I've given up spraying any gloss coat for that very reason! With aircraft it's easier due to their streamlined shape, but armour has so many perpendicular surfaces that pooling becomes a real problem. So now I apply it with a large flat brush , it's slower, but you have more control. Plus I've found that 3 thin brush coats will provide a better gloss than 1 or 2 airbrushed coats.
Thinning the Clear with water will only make matters worse I reckon. The thinner liquid will be more inclined to pool.Comment
Stick with enamels Grant, they're great! Haha I'm one of the few who still uses them on here
If you do go with acrylics, be prepared for all the problems & frustration associated with them.. and whatever brand you choose... DON'T use Humbrol acrylics, coz they're rubbish!Comment
Just my opinion, but enamels spray like a dream. You can use white spirit to thin & clean the airbrush.
Plus you'll avoid the typical issues that acrylic users suffer. Probably the easiest acrylic to get into at first are Tamiya. As long as you don't spray from too far away, they're pretty forgiving. The only downside is the lack of specific paint colours.Comment
Hmm that's a difficult one to answer, because smells are different from one person to another.
Personally I don't find it bad. I've had people come round just after spraying & they've never mentioned it. They're not being polite either, usually they're interested in my model making.
But I do have a spray booth; homemade but it does the job.
If you have any Humbrol tinlets knocking around & some white spirit, give it a try and see how it compares to acrylics.
It's my view that many users of acrylics who say enamels are too smelly simply haven't tried them. Most people take up the hobby or return to it, read on forums like this that enamels stink the place out & go directly to acrylics.
Then they spend valuable modelling time posting up threads asking for help with clogging, tip dry & what thinner/cleaner to use :PComment
