I may give the old enamels a try then it's what I'm used to and try some washes on this model then
Klear
May I suggest you use odourless thinners? Winsor & Newton 'sansdoor' is ยฃ8 for 250 ml, but if you only use it to actually thin your paint (and use White Spirit to clean up) it'll go a long way. it has a very mild smell, and white spirit is a bit whiffy, especially if sprayed! I'm sure if you shop around, it's available even cheaper!Comment
