The threads on my tube of Green Putty are faulty so that the top will not screw down properly. I can't tell if it is the tube or the plastic cap that is at fault
That means the filler at the open end of the tube is becoming quite hard; lately I've had to poke through with a metal rod to get at the soft stuff; eventually the whole tube will become solid
Any suggestions as to how to make a better seal?
