Glass crack
    Glass crack
    Hello!
    I am not sure is this right topic but i found crack in my plane glass. Anyone can tell what is the smartest way to fix it ?
    ( Sorry for bad english )
  • eddiesolo
    • Jul 2013
    • 11193
    There is no 100% fix. If you know the kit maker you could ask for a replacement or source a aftermarket part.
    You could glue the join but the crack would always be visible.
      Alright, thanks for help!
      • eddiesolo
        • Jul 2013
        • 11193
        One way around is to do it on the ground and add a tarpaulin over it, looks like a glass section for a gun, what plane is off?
        • stona
          • Jul 2008
          • 9889
          I've used G S Hypo cement to fix a canopy and the result was acceptable, but not perfect.
          I've seen it suggested that clear varnish can be used. but I couldn't make this work at all.
            This is 1:32 Revell Junkers Ju88 A-4's glass part. I try my best to fix it, i will update progress soon.
            • eddiesolo
              • Jul 2013
              • 11193
              Right, the rear section of the canopy. I have had a look and cannot find any aftermarket canopies for this model, doesn't mean there are not any, just I haven't been successful.
              Hope you get it sorted.
              • PaulTRose
                • Jun 2013
                • 6457
                • Tattooine
                id try using old formula Kleer to 'glue' it together.....then dip the whole thing in it
                Per Ardua
                  • 18266
                  Well I guess that as good a place as any to start would be here http://www.revell.de/en/service/serv...-building.html
                  They are normally pretty good.
