Micro sol/set tide marks
  • rickoshea52
    • Dec 2011
    • 4076
    • Rick
    How do I make these tide marks disappear? I have use Vallejo paints and varnish so far then applied the decals using micro sol & set as per the instructions but the next day this ugly tide mark is present and I cannot get rid of it using for Microsoft or clean water.
    Any tips please?
  • stona
    • Jul 2008
    • 9889
    I use a gloss varnish under decals and have suffered a similar problem. Another coat of varnish over the decals, before the final coat, has always cured it.
    • rickoshea52
      • Dec 2011
      • 4076
      • Rick
      Let me get this straight Steve, I have applied the decals with microsol and this is the result, my next step would be application of a sealing coat of gloss varnish (only gloss varnish has been used so far) - you saying that that dealing coat of varnish should make this disappear?
      Thanks for you advice so far.
      • colin m
        • 8740
        • Colin
        • Stafford, UK
        I'm with Steve. I know it's a brave thing to do, but it works. Gloss, then wash if wanted, then matt.
        • stona
          • Jul 2008
          • 9889
          Yep! The gloss I use is old fashioned Klear, but it is just a cheap gloss acrylic varnish and does not possess the magical properties that some ascribe to it. This has worked on several occasions.
