Inspired
    Inspired
    So. I was having a good nose around SMF, reading topics that sparked my interest when I happened across a thread where several members talked about making use of household items and cheap stuff from pound shops and it got me thinking. I work with computers and a majority of our work involves laptops. I have already gotten a load of white LED's from broken screens (that one was my boss's idea) so I got to thinking about what else can be rescued from broken laptop parts that would otherwise go in the bin.
    So far, I have found some very fine plastic mesh from speaker coverings and cooling vents that could be made use of.
    I also think I can make use of the clear plastic light guides that some laptops use to shape the activity LED's output.
    The screws in laptops screw into brass threaded inserts. I can easily remove the inserts with a soldering iron then use them on models where a removable panel would be useful as the screws are nice and small.
    If anyone has any other idea's that could inspire me further...
  • dave
    • Nov 2012
    • 1828
    • Brussels
    The cooling fans can be used as ventilation fans for industrial buildings, underground bunkers etc.
    • Gern
      • 9214
      Some of the electronic components you find soldered onto the PCB make useful boxes, small gas cylinders etc if you want to detail up a cockpit for example (obviously not so much use if you want every detail totally accurate). You'll probably need a soldering iron to remove them without breaking them though.
        It's a good idea but surface mount components are a nightmare to remove as they are glued onto the board and flow soldered. Using 2 irons to heat both ends and burn off the glue works but it is very easy to overheat and destroy the component.
          • 18269
          Small PCB's make quite good "decoration" for sci-fi builds....
          • Gern
            • 9214
            I agree they can be impossible to remove sometimes but .....
            And as Ian said, you can get some good Sci Fi bits:
            The figure in Pic 3 is from a set of 28mm Sci Fi figures. One day maybe, I'll get round to doing the dio I have in mind for this!
            • eddiesolo
              • Jul 2013
              • 11193
              Indeed they can, this a fan and heatsink out of an old xbox 360.
                Hmm, interesting. The type of components pictured are conventional mount rather than surface mount. A very good source for those is old audio amplifiers.
                A word of warning tho, be wary of stripping down valve amps. Some components can hold a hefty charge for a long time.
