Best brushes for liquid cement
  • johnm93
    • May 2016
    • 71
    As the title says, what brushes are best to use instead of the one built into the bottle?
    I find the brush too large and using a decent paint brush which goes hard seems a waste...
    Get the stuff with the needle tube applicator I know airfix and revell do them, failing that dab some on a bit of card with the brush then use a cocktail stick to apply it.
      Cut the supplied brush off & attach a better one with epoxy
      • stona
        • Jul 2008
        • 9889
        I use an old synthetic paint brush, I would have to check the make.
        It doesn't go hard, the cement just evaporates from the brush.
          I use an old Revell brush (Size 0), with a bit of masking tape around the end so I don't use it for painting by accident.
          I let it dry & then when I use it next, I just rub my nail through it & it is ready to go again.
          • rickoshea52
            • Dec 2011
            • 4076
            • Rick
            Keeping some brushes aside for specific uses and marking them is a top tip.
            • johnm93
              • May 2016
              • 71
              Now, why did I not think of that...?!?
              • BarryW
                • Jul 2011
                • 6028
                I use Mr S Cement. The brush in those is smaller than the Tammy one and is one of its real advantages.
                • Robert1968
                  • Mar 2015
                  • 3596
                  I like the replies here as I have used the odd brush as sometimes tamiya thin brush sometimes is a bit fiddly when you only want a tiniest of amount.
                  I like the idea of a dropper too and I'll have to look into that one ( saves the brush and the excess clean up
