Stand problems
    Stand problems
    I have created a stand using a small table leg attached to a square block as a base.
    The table leg is hollow and is around 32mm dia. This slots on to a small pipe on the model itself which is around 30mm.
    The problem is that the model lists forward and I need to make it secure. I've tried to make the small pipe diameter bigger by using tape wrapped around, but the model is still listing forward.
    Any suggestions? I can't really change the stand much now as it's wired in, but open to options.
  • flyjoe180
    • Jan 2012
    • 12407
    • Joe
    • Earth
    Can you fit ballast to the rear section of your model?
      Good idea, but I've actually turned the part on the model sideways and now it's much better.
