Attaching models to bases
  • BBdave
    • Aug 2014
    • 825
    Maybe a silly question but do you folks glue/permanently attach your models to bases/dioramas?
    No such thing as a silly question Dave. I usually drill a hole through the bottom of the hull & then screw it to the base.
    Failing that, PVA glue works!
      for aircraft I put a drop of medium cyno on the wheels and simply stick it down.
      Theuns
      • stona
        • Jul 2008
        • 9889
        Depends on the base, but generally I drill the bottom of the wheels and insert a piece of wire long enough to pass through holes in the base. Put the model on the base, passing the wires through the holes and then semi-permannetly fix the wire to the underside of the base (I've used everything from Blu-Tac to gaffer tape).
          • 18264
          I give figures a wire in the bottom of their foot if they are standing and push it into the (foam) base.
          Aircraft just sat sitting there, Only put them on a base sometimes for a photo, then it's removed and put on a shelf.
          Armour....Hmmm They normally go on a base with so much mud and muck that they just stay put. Otherwise again just lose on a base for a photo then off to the shelves.
          If you are going to show them in a contest a little sign "This model is not attached to the base" more often than not prevents judges tipping them off the base.
          But it has happened!
          • Snowman
            • Oct 2014
            • 2098
            Since I have started to make bases for my builds and have used iether a small nail (panel pin) or rigid wire that is glued into a hole in the base and the slid or glued into another matching hole in the underside of the model. Whatever works for you.
            I find that this works especially well for those random bits on a dio that tend to get accidentally knocked off in transit or handling.o_O
              I use a double sided tape, cut it really small to hide it. Sometimes CA glue
