new to scale models.
    hi.. im just starting out in scale models.. i am trying out a Mclaren MP4/7 F1 car.
    sadly i have made a complete mess of the body trying to spray it.. i was wondering if anyone here has a spare or know where i can source 1.. many thanks.
    oops.. forgot to mention.. it is a tamiya 1/20th scale.
      Hi and welcome!
      Making a mess of the first 10 kits or so is part of the game and we've all done it
      If it's the Tamiya kit then they run a spare parts service. (just like all manufacturers should do, but some don't - like Squadron!)
      Go through your local agent and you should be able to order spare parts, unless it's a really rare or old kit?
        tried that.. they just said its not is stock even from tamiya
        • John
          • Mar 2004
          • 4638
          • John
          • Halifax
          Canโ€™t you remove the paint and start again?
          www.scalemodelshop.co.uk
            Worst case scenario you can get a whole kit for ~ยฃ30 and salvage the build.
            Find many great new & used options and get the best deals for Tamiya 1/20 Scale Limited Series McLaren Honda Mp4 / 7 Model Plastic 25171 at the best online prices at eBay! Free shipping for many products!
            I'm surprised Tamiya didn't have any spares since they did a rebox in 2014, but it's not impossible they are totally sold out.
            But like John suggested you should always attempt to remove all paint and start again.
            A bit of cellulose thinner, or even isopropanol alcohol should remove the paint depending on what paint and primer you used?
            Don't use acetone because that's too aggressive on the plastic.
            What paint have you used and what is the problem that has occurred?
              i used the tamiya spray.. ts36
              the problem is/was.. the paint leaked under the masking tape,,, guess i didnt press it down properly at the edges..
              i tried overspraying with white.. but trying to cover neon red is near on impossable, lol.
                Cellulose thinner, or iso, on a q-tip can solve that problem and then you just spray that area carefully again.
                Always spray at an angle from masking tape and never towards the edge, that way you don't have to press down the masking tape so much and no paint can get under the masking tape!
                This isn't always possible if using a rattle can, but for airbrush it's the usual procedure.
                  I'm with John, Windex/detol/ mr muscle blue window cleaner will strip that nicely, hard though it is to believe! I let palletes get well gummed up with mixture of Tamiya and Vallejo paints, they soon clean up with Mr Muscle blue window cleaner!
                    only thing i have in house at the moment is white spirit used for cleaning gloss paint from paintbrushes..
                    ill look for something when i go shopping again.. thanks all this advice is great.
