Hi, Currently doing my first 'proper' build, which is coming along, a few mistake's but that's to be expected! Had some good advice from you guys so far, so was after some more help regarding 'attaching small pieces.' Building Krupp Protze truck and in the instructions it says that certain small pieces should be painted first, like the rifle and spade etc. How do you find it best to glue these on once painted, of course the glue messes up the paint so do you glue them on and then attempt to paint them or do you find where they go and avoid painting that spot? I would imagine painting them after being glued would be very fiddly, but equally, leaving a spot unpainted just as tricky.
Thanks in advance.
Thanks in advance.
