Once chipping solution is applied and then painted over, how long can it be left for before doing the chipping.
For example could I chip away the following daybor a week later.
Do you guys mind If I join in please ?
Gavin is quite right, the only thing I would add is the longer you leave it the harder it is too remove, as I know only too well:hugging-face:
