Washes in acrylic ?
Smoke translucent acrylic was mentioned in an earlier post. It is really good for toning down the polished vacuum chromed parts in car and truck kits.Comment
Washes stress me out a bit (although not as much as decals). So, good luck with your endeavours.Comment
Okay, thanks. Worth a try for certain.
The whole business of getting the b@st@rds to lie flat and not silver around the edges really winds me up.
Am enjoying a break from all that, with the spring/summer figure season in full swing! Happy boy on home ground.Comment
Washes like most things take a bit of practice, experimentation and perseverence. It will always come good in the end. I have also tried diluted art shop inks as washes and tried water colours as well!Comment
Games Workshop used to sell inks as part of their line of paints, and though I like(d) them, you have to be aware that an ink is rather different from a wash. Chiefly, the colour will be much stronger, and you’re mostly limited to a few main colours. You could mix them, but it doesn’t have the flexibility of colour of using thinned paint as a wash, where you can have pretty much any colour of wash you might need.Comment
There are lots of different types of wash and each is slightly different in application or make-up. Pin washes on tanks and panel line washes on planes are examples, and filter coats added to break up surfaces is another. Filter coats usually don’t need a gloss coat, but perform better over a pre-wetting of thinners, and the pin and panel liners working better over gloss coats...you pays yer money and takes yer choice.....
Inks are a little different, and are quite often used in the miniature figure painting discipline. They are usually used to give an easy “shading” effect when washed over the figure as they are not as opaque as paint. I find them great for giving body to painted hair and fur.....
They can be thinned and cleaned up with water as well.
For interest, some companies now make pre-made washes for this purpose, Vallejo and Citadel come to mind but I know there are others.
For part time figure dudes some companies, such as Wargames Foundry, actually sort their paint into triads for certain colours, making shade/basecoat/highlight technique easier for those that don’t want to learn colour mixing.....
There’s loads of technique out there, look at other modelling disciplines sometimes and see what you can steal
TimComment
Figures, planes and vehicles aside, I have found Vallejo Model Wash very useful for the buildings on my diorama.
Mostly I painted using artist's tube acrylic paints (sprayed or brushed) onto plaster (the original Verlinden casting), resin (the doorway from Reality in Scale) or Das clay (applied over my scratch built foam board).
Obviously I was very keen to avoid any solvents that will attack the foam board - or the insulation board that I used for the base.
[ATTACH]305580[/ATTACH]
As you can see from the image above, the effect isn't exactly subtle - but then I didn't want it to be: I wanted the details to leap out.
Having said that, you can see some pooling around the doorway which will be settled with pigments. At this point, the cobbles in the foreground have yet to be washed (so you are looking at simple contrasting colours) and the groundwork hasn't been added either...Attached FilesComment
