What Models have beaten you??
So far......my one and only binned kit was this,
[ATTACH]318889[/ATTACH]
The plastic was like granite and there was so much flash and misalignment that after getting halfway through I just fed it to the bin!
What I found annoying was seeing others make a cracking job of the kit! I must of had a bad one:smiling5:Attached FilesComment
The one that beat me was an Airfix ship in a bottle model of the Charles Morgan, a wooden sailing whaler.
Fought ill fitting parts, filler etc. Got all the rigging done, dry run on the mast erection. Then it would not fit into the bottle, fractionally too wide for the neck. Finally broke it trying to ease it through. Landfill for the kit, recycling for the bottle.Comment
Yet to be beaten Dave but I have not been modelling as long as the rest of you. However there have been a couple that have hovered over the bin and I would never touch again. Mirror Models CMP and Roden Holt 75.Comment
You started the same time as me ! but you have been trained by the man from the Darkside, one Simon T of the Dales. He goes where no one dares when It comes to modeling
JR :smiling2::smiling2:Comment
What I found annoying was seeing others make a cracking job of the kit! I must of had a bad one:smiling5:Comment
Dave,
For me it was the Dingo from Miniart and more recently the FW 190 a-8 from Eduard...
All those gaps and pieces of plastic that snapped right of in all the wrong places...
Ooooh the memories....
*sits alone in the corner rocking back and forth while sucking is thumb*
SjorsComment
This one was my biggest fail...could not get the deck to fit the hull no matter what I tried. Clamps worked until the cement had set, but the hull would soon spring back out of shape. I was quite young at the time. might give it another go one day...but don't have the space at the moment.Attached FilesComment
When it is a bad kit can we not send it back to the original company? After all our hobby is their business. Feedback is useful. I know some kits are remakes but somebody is responsible.Comment
Every kit I've ever built has beaten me somewhere along the line that's why mine always have loads of upgrades or modifications to hide all my mistakes.
Pete.Comment
Sometimes, it's not the manufacturer, but the modeller! It's exasperating when you see the same model that you canned, made up by a 12 year old on his first construct!
If you have problems with a model, email them, go on their Facebook page - you never know, you might get a result, or meet others with the same problem........
DaveComment
None so far. Being a very competitive personality, I persist beyond the reasonable. Scratching or semi-scratching around the shortcomings. Not always with great result, but OK from two feet. An advantage of working only in 1/87 scale. PaulEComment
