Modelling Drill
  • Steve Jones
    • 6615
    Modelling Drill
  • Steve O
    • Dec 2017
    • 327
    I have the same set and turn them with my finger and thumb, no problem with plastic.
      Yup,
      I've had several sets of these drills - they don't really work with hand held power tools - too fragile, they won't take any side loading - they might work with a bench drill - but that's rather expensive.
      I use pin chucks - good quality one, with rotating end & swappable collets - I got mine from Amazon..................
      [ATTACH]319809[/ATTACH]
      Just make sure that the chuck can accommodate the drill shank!
      • Steve Jones
        • 6615
          • 15681
          Hi Steve
          I have had this for about 5 years. Works really well. Has the big advantage that the speed can be adjusted from zero to max.
          [ATTACH]319810[/ATTACH]
          • scottie3158
            • 14201
            • Holbeach
            I'm with Dave and Steve I have a selection of pin vices they work well for me.
              One of the problems of power drilling polystyrene. is that it is a thermoplastic - as it heats up, it gets sticky & melts. This then can stick to the colder drill, and either break the drill, cause a ragged hole, or not drill at all! A pin chuck - you can't really turn it fast enough to generate enough heat. To truly drill at speed, you would have to have some form of coolant/lubricant - think dentists' drill!
              You can use a power drill, but you have to take it slowly, not apply too much pressure, and try not to drill too thick a work piece - and keep on backing out to remove swarf. In the end doing it by hand works better for me - I did try an Archimedes drill[ATTACH]319821[/ATTACH]
              BUT, you need two hands to use it - the pin chuck only one!
              • stillp
                • 8091
                • Pete
                • Rugby
                You don't need two hands for an Archimededs' drill Dave. Index finger goes on the rotating dimpled part on the top, then you should be able to move the part that causes the rotation up and down between thumb and third finger. Needs practice, but doable.
                I keep meaning to try a diode in series with my Dremel to see if I can slow it to a more manageable speed.
                • Steve Jones
                  • 6615
                  That could be the thing for me Jim. I shall start trawling the tinternet and see what I come up with. Many thanks
                  • minitnkr
                    Charter Rabble member
                    • 7529
                    • Dayton, OH USA
                    I've tried any number of solutions over the years & have settled on pin vices as described above. I have found a cutting disc specifically for plastic in automotive use that works quite well w/my venerable Dremel. PaulE
                    • Steve Jones
                      • 6615
                      The issues with the Dremmel is the vibration due to the high speed which seems to effect accuracy. Unless I have the "off the back of the lorry" version:smiling5:
                      • BigGreg
                        • 2182
                        I use a Dremmel with different speed level and personally i have no issues with Dremmel :-)
                        • BigGreg
                          • 2182
                          By the way i just received in the mail a bit that i ordered..... i think they made a mistake with the size......:smiling::smiling::smiling5::smiling5::s miling5::smiling6::smiling6::smiling6::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy:[ATTACH]319833[/ATTACH]
                          • Gern
                            • 9213
                            So what scale model would you need to use that on? 72/1 perhaps?
                            • BigGreg
                              • 2182
                              ... Sorry i know it's dumb... but i could not resist...ahhahahahahhahhahahh
                              :tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy::tears-of-joy:
