By tips on applying instrument panel decals? I found a thread in another forum saying file off the detail before applying the decal, but that is not practical on the more intricate panels. Will the decal sticker on ok if I apply it over the raised details?[ATTACH=CONFIG]n[/ATTACH]
Instrument panel decals
GuestTags: None
Hi Lucy
I'm sure some of the aeroplane builders will offer more advice but I think it will depend on how large the decal is, how raised the panel detail is and how much decal softening stuff you use. I use Microscale Micro Sol decal setting solution.
Jim -
Lucy,
apply a coat of clear gloss varnish over the panel. - You might have to use a decal softener to get them to sit down, if you can't file the panel smooth. There are several makes available like this * decal fix * from SMS. One part softens the decal, the other, as it dries pulls the decal down over the surface. It won't work miracles, though!
DaveComment
Just been out to Hobbycraft and bought Humbrol decalfix. I'll try it later on a spare decal. Thanks for the tips.Comment
Lucy,
I've been using Decalfix - it can be a bit fierce, and moving the decal after placing it can be tricky - it also seems to make the decals stick to my fingers! Humbrol do a tutorial on decalfix on YouTube, * decalfix * that may be of use
DaveComment
[ATTACH=CONFIG]n[/ATTACH]Success! Ok so it's nearly midnight, but with help from all your tips and Humbrol decalfix, got the cockpit decals done. Eyebrow tweezers, cocktail stick and a lot of patience did the trick. Just need to leave them to dry overnight. Thanks everyone.Comment
Good advice from the guys Lucy. One thing I do where possible is to cut the decals into smaller pieces and apply them separately where there is a large 'step'. You MUST have a new blade in your knife before cutting decals though! A used blade is likely to tear the decal rather than cut cleanly.
Part number 5 on your first picture is an example. If the decal was originally supplied as a single piece to cover the whole panel, I would cut it into three exactly as the maker has done - decal numbers 67, 68 and 69 - then it's a much easier fix.
I might even consider doing the same with decal 74 depending on how confident I felt about it sitting properly in one piece. And for certain sure I'd cut out decal number 73 if it was attached to the main panel decal!Comment
You cracked this nicely...
Personally, I use micro Sol and Set..... I use Sol to position the decal, and then press it down using a folded damp paper towel. Once I am happy with the position I flood it with Set to soften and conform the decal to the surface. Don’t touch it again until it’s dry, then if it hasn’t quite conformed, repeat the application. Air bubbles and slivering can be addressed by pricking the decal gently with a very sharp blade or needle and reapplying Set....
Gen’s tip is very useful, as is Dave’s, but if you use cotton buds, wet them and wring them out first to stop them shedding hairs into the decal...and don’t use them once you have applied Set as the decal may disintegrate.....Comment
Hi Lucy
Glad you sorted it. Have a look at THIS. The guy is a bit long winded but gives sound advice.
Tim's method is pretty much what it shows on the video - Tim just got Set and Sol the wrong way round :smiling:
Dave's idea of cutting large decals is something I haven't thought of but it sounds like a really good idea :thumb2:
JimComment
