Good scriber to buy?
  • BattleshipBob
    • 6802
    • Bob
    • Cardiff
    Evening, not sure if this is the right place?
    Looking for advice ref buying a good scriber. Will need one after ruining panels no doubt lol
    Thanks bob
  • scottie3158
    • 14202
    • Holbeach
    Bob I use the Tamyia offering it is easy to use.
      • 18908
      Hi Bob
      I have several, and they all have uses.....
      An engineering scriber is a useful general tool. Holds an edge for ever....leaves a raised edge to the furrow though.
      Tamiya scriber is good, commonly called a scrawker, they can be fairly easily made yourself if you know how...basically cuts out a furrow, so no real discernible edge to the cut.
      I also use a couple of Lino/scraperboard artists cutters as well. They are really good for some sorts of plank lines.....again, leaving no raised edge, but not cutting square slots like the Tamiya tool.
      • BattleshipBob
        • 6802
        • Bob
        • Cardiff
        Thanks both
        Much appreciated
        Bob
        • minitnkr
          Charter Rabble member
          • 7543
          • Dayton, OH USA
          I use the back edge of Xacto #11 blades. PaulE
          • BBdave
            • Aug 2014
            • 825
            I've heard good things about the UMM scriber tool but not sure they are available in the UK.
            • SimonT
              • 2824
              Been using an Olfa P cutter for 20+ years to cut plastic card for scratch building but they can also be used for panel lines
              I think the Tamiya one mentioned above is a licensed version of the same tool
                • 18271
                I use the Tamiya one. the handle jut sits better in my hand. You can hold it like a pen almost. The Other one the handle is a it chunky and you tend to hold it like a hammer!
                A pin style scriber is very good for inside corners.
                  Just rebranded. On the back of mine, moulded into the plastic, it says โ€œOLFA JAPANโ€.
                  I agree this is a very good tool for scribing lines in plastic and cutting thicker sheets, though.
                  • BattleshipBob
                    • 6802
                    • Bob
                    • Cardiff
                    Thanks to you all, much appreciated
                    Will get a tamiya one as they are not too much of the hard earned!
                    Bob
