Has anyone tried this.
    Has anyone tried using this for press or stamp molding if so what do you think..
    Newplast Non Drying Modeling Clay.
    For the best in fibreglass supplies look no further than MB Fibreglass. Here you'll find all you need from silicone moulding rubber to liquid plastics at great prices
    Pete.
    Hi went a head and got some will see what it's like and report back after test.
    Pete.
    • scottie3158
      • 14241
      • Holbeach
      Pete,
      Looks interesting.
        Pete,
        Looks interesting.
        Hi Scottie, I'm trying to find an alternative to plasticine which is a bit sticky and oily, I think it's what MickC uses but as he has stopped posting I don't know.
        Pete.
          Pete.
          Pete.
          Read about it after you had posted , seems could be ok, had mention of mould making in the blurb
          Good luck
          • minitnkr
            • 7564
            • Dayton, OH USA
            Did you try a different brand? I use Klean Klay modeling clay. It is not oily and is a bit sticky, but not very. It takes paint well and doesn't dry out or shrink over time (years and years). PaulE
            • Dustbin
              • Jan 2009
              • 121
              I have used this before for moulding spare parts for a diorama, I found it worked well as long as you dont let it get too warm. Its definately not as oily as Plasticene.
              Paul
              • Neil Merryweather
                • Dec 2018
                • 5204
                • London
                I used it for the water in my LCVP build. it was fine for that , I didn't realise there was any difference between it and plasticine.
                If you want to use it for press moulding I would recommend putting in the fridge for awhile to make it stiffer.
                HTH
                Neil
                  Hi PaulE , hadn't heard of it before just had a quick look for it, looks like you can only get it in the US.
                  Thanks for the information though.
                  Pete.
                    Paul
                    Hi Paul, it doesn't smell like it and your right it's not as oily as plasticene. Will be playing later.
                    Pete.
                      HTH
                      Neil
                      Hi Neil I did follow your build but didn't realise it was Newplaster you used. Good tip about putting it in the fridge for while.
                      By the way top job in the LCVP build very impressive.
                      Pete.
                      • Neil Merryweather
                        • Dec 2018
                        • 5204
                        • London
                        Pete.
                        Very kind, Pete, Thanks
                        • stillp
                          • 8102
                          • Pete
                          • Rugby
                          Hobbycraft among others have it in the UK.
                            Hi Pete cheers for the information.
                            Pete.
