(Beginner) Washing the parts before starting
    Hi, Absolute beginner here.
    I'm writing down all steps before starting tonight, as for the washing part..
    Do I leave them in soap + warm water for a while, if yes how long? And after that should I just leave them out to dry on a towel?
  • stillp
    • 8096
    • Pete
    • Rugby
    Hi Miguel, many people don't bother washing the sprues, but I've never heard of anyone having trouble because the parts are too clean! I would just swirl tthem about in a bowl of warm soapy water for a few minutes, then rinse, shake off as much water as you can, pat dry with a paper towel then leave them to air-dry.
      • 15727
      Hi Miguel
      I totally agree with Pete. Personally I never wash plastic sprues. THIS recent thread may be of interest.
        Thanks stillp I'm going to follow your advice, How long do you guess the air drying would take? I suppose overnight?
        • stillp
          • 8096
          • Pete
          • Rugby
          Depends how warm and airy the room is. An hour or two should be plenty.
            • 18271
            Make sure that the water is just warm and NOT hot. Plastic and hot water are not a great mix. Wash them off and lay them on kitchen roll befor you go to work/Bed and they should be ready when you come home of get up!
            Moved this to modelling chat.
            • PaulTRose
              • Jun 2013
              • 6485
              • Tattooine
              warm water......old tooth brush.....very gentle scrubbing, try not to break any thing.......stand up some where to air dry over night
              Per Ardua
              • scottie3158
                • 14211
                • Holbeach
                Hi Miguel,
                First welcome to the forum and as for washing the sprues, the other guys have said it all.
                  • 15727
                  The main reason I don't wash the sprues is that I feel that all the handling and sanding the parts are going to get putting the model together, I'm better off cleaning just before priming/painting.
                    • 18925
                    Hi Miguel
                    Welcome aboard.
                    • Peej
                      • Aug 2014
                      • 919
                      Hi Miguel. Welcome to the forum. In the past I have washed some kits and others I have not. I haven't noticed any difference so now I don't bother and just start with the build.
                      • BarryW
                        • Jul 2011
                        • 6029
                        I also never wash the sprues, but before spraying paint I do wipe the parts to be sprayed down with i.p.a., getting into the detail with a cotton bud. Also it is worth using disposable gloves when handling after that, as finger grease can be an issue when spraying. Also this washing does remove dust etc from sanding. Be careful not to jeave fibres behind caught on the detail.
                          Thanks for your reply! What do you mean with I.P.A? I only know that as type of beer.
                          What do you mean with "jeaving fibres behind caught on the detail"?
                          • BarryW
                            • Jul 2011
                            • 6029
                            If you are rubbing i.p.a. into detail with a cotton bud, kitchen towel or cloth then fibres will get caught up on that detail.
                            ipa is what our American cousins call rubbing alcohol and stands for Isopropyl Alcohol. You can get it off Amazon and if you buy it in larger quantities, it is very cheap. It is good for cleaning brushes and air-brushes of acrylic paint. If you do buy a large quantity then be careful of storage as it is flamable (I buy boxes of 5 x 1 litre bottles at a time as it is easier to dispense than larger containers)
                            Among the uses I put it to:
                            ...Cleaning parts pre-painting as mentioned
                            ...Rinsing through the airbrush for colour changes (I use MRP solvent based acrylic) it suppliments using more expensive thinner/Mr Tool Cleaner
                            ...Washing brushes that I have used with Vallejo water based paint
                            ...Liquid seam sanding. This is a good option for removing surplus filler when you have filled a seam and want to avoid losing detail with ordinary sanding. Vallejo Plastic Putty or the Gunze fillers, Mr Disolved Putty and Mr Surfacer work well with this. You do have to rub hard with the cotton bud and let the ipa soak the filler a bit in the process.
                              • 15727
                              Hi Barry
                              Now that sounds like a very useful idea.
                              Thanks
