Face mask
  • Bortig the Viking
    • Mar 2019
    • 780
    Face mask
    Hi, can anyone recommend a face mask to use when airbrushing.
  • Tom Rigg
    • Apr 2015
    • 101
    Do a site search. I've seen at least one thread about masks
      • 18907
      Hi Mark
      Something like this:
      3M Paintshop Respirator Kit 06782 3M Paintshop Respirator Kit 7500 provides comprehensive protection and is designed for use in environments with organic
      Should sort you out.....
      • Bortig the Viking
        • Mar 2019
        • 780
        Thanks
        • Bortig the Viking
          • Mar 2019
          • 780
          Hi Mark
          https:tongue-out3:/refinishsystems.c...iABEgI0C_D_BwE
          Thanks for that, I'll look like one of the pest controllers, do I get a jumpsuit to go with it or am I on the wrong forum. :tears-of-joy:
            • 18907
            Hi Mark
            You can get them here if you are so inclined.....
            Personally, after having to wear one for some number of years at work, I wouldn’t bother
            As to pest controllers, they wear them for a reason, which happens to be the same reason you should wear one......lung protection...:thumb2:
            • Bortig the Viking
              • Mar 2019
              • 780
              Hi Mark
              https:tongue-out3:/www.safetyshop.co...ith-boots.html
              :thumb2:
                That 3M mask is a good one, but as someone that wears a mask day in, day out I'd suggest you also take a look at the Moldex 7000.
                Personally I find them more comfortable, the initial purchase cost is slightly lower and replacement filters aren't much more expensive. The filters do have a "better" rating though, especially for particulates (P3 instead of P2)
                  • 18907
                  Looks a good call Andy, I just went with 3M because I used to use them extensively at work...
                  Just for those that don’t know so much about this stuff, I think the most important factor for us is probably the organic solvent (A) rating.....closely followed by the particulate (P) rating, higher numbers being better....a spray mask should certainly have a filter fitted that has both A and P ratings though.....
                    One thing I like about the moldex is the ease of swapping the filters around. If you were so inclined you could easily remove the main filters and pop on just the particulate ones for sanding etc, although it's not something I've ever done myself.
                      • 18907
                      What amazes me after using one is how much colour appears on the outside of the filter....
                        Indeed. It just proves how much could be getting into your lungs if you weren't wearing one! :sick:
                          Which ever mask you get Mark get the correct filter cassettes. Plus a good fitting nose mouth close fit
                          Assuming you use acrylics a filter for particulates & lacquer. A good manufacturer will list these with
                          the specification. Plus do not use the filters for ever they need replacing.
                          Naughty myself & was using the same filters for a good time. Replace & what a difference.
                          I use a ValueAir Plus which is a good fit good adjustment & provides the necessary filters. But there
                          are a number of others. Found it best to put in a search rather than buy on Amazon which is restricted
                          in variety.
                          • Bortig the Viking
                            • Mar 2019
                            • 780
                            Thanks all
