Drill sizes
  • Bortig the Viking
    • Mar 2019
    • 780
    Drill sizes
    Hi, have been offered some drill bits, good quality, but they are priced per drill bit. My question is what sizes have people found to be helpful and of use, I don't think I need that many sizes but wanted your opinion. Thanks Guys.
  • John
    • Mar 2004
    • 4634
    • John
    • Halifax
    I can give you an idea of our best sellers, these are sales over the last 2 months, you can tell what is more popular.
    0.25mm Drill Bit 19
    0.3mm Drill Bit 32
    0.4mm Drill Bit 22
    0.5mm Drill Bit 37
    0.6mm Drill Bit 16
    0.7mm Drill Bit 10
    0.8mm Drill Bit 4
    0.9mm Drill Bit 4
    1.0mm Drill Bit 7
    1.10mm Drill Bit 5
    1.2mm Drill Bit 4
    1.5mm Drill Bit 4
    1.70mm Drill Bit 1
    1.80mm Drill Bit 2
    1.90mm Drill Bit 1
    2.00mm Drill Bit 7
    www.scalemodelshop.co.uk
    • Bortig the Viking
      • Mar 2019
      • 780
      0.25mm Drill Bit 19
      0.3mm Drill Bit 32
      0.4mm Drill Bit 22
      0.5mm Drill Bit 37
      0.6mm Drill Bit 16
      0.7mm Drill Bit 10
      0.8mm Drill Bit 4
      0.9mm Drill Bit 4
      1.0mm Drill Bit 7
      1.10mm Drill Bit 5
      1.2mm Drill Bit 4
      1.5mm Drill Bit 4
      1.70mm Drill Bit 1
      1.80mm Drill Bit 2
      1.90mm Drill Bit 1
      2.00mm Drill Bit 7
      Hi, thanks, didnt think I'd need many, I have a few already so that's ok.
      • stillp
        • 8090
        • Pete
        • Rugby
        The small ones are only popular because they break so easily!
          You can also get sets with drills from 0.3 mm through 1.6 mm.
          That’s harder to answer than you might think, because it depends a lot on what you need the holes for. If, for example, you usually make hatch handles on tanks from 0.5 mm copper wire, you’re bound to get a lot of use out of an 0.55 mm or 0.6 mm drill, for example, but if your usual wire is 0.7 mm then those drill sizes will see very much less use for you In other words: think about what you intend to use them for, and you can probably answer your question better than any of us can.
          • Bortig the Viking
            • Mar 2019
            • 780
            That’s harder to answer than you might think, because it depends a lot on what you need the holes for. If, for example, you usually make hatch handles on tanks from 0.5 mm copper wire, you’re bound to get a lot of use out of an 0.55 mm or 0.6 mm drill, for example, but if your usual wire is 0.7 mm then those drill sizes will see very much less use for you :smiling3: In other words: think about what you intend to use them for, and you can probably answer your question better than any of us can.
            Hi, thanks for that, wise words are spoken.
            • John
              • Mar 2004
              • 4634
              • John
              • Halifax
              You don't need that many, this is all we stock, but it gives you an idea of how they sell, as Peter said the small one's break easy
                • 18894
                Another approach is to buy 0.3, 0.6, 1.0, and 1.3 and then a set of tapered broaches. You can then open the holes out to whatever size you want....
                  Don’t forget that you need a pin vice (or whatever) that can actually hold the bits. Mine has trouble with about 0.5 mm and down, for example.
                  • Bortig the Viking
                    • Mar 2019
                    • 780
                    Hi, yes that was a thought I had, the drills I have/get are of set shank sizes not the size of the business end.
                    But thanks to all who have commented, it all helps.
                    • JR
                      • May 2015
                      • 18273
                      Referring to what Jakko has said about a pin vise Mark I had a cheap one at first, always trouble with those very small drills , bought a Tamiya, with a large and a small chuck. What a difference, takes the smallest of drills with no loss of grip.
                        • 18894
                        Good point about the pin vice. I bought an eclipse pin vice with three collets about 35 years ago and it is still going strong. A tool factor such as Shestos will have them. Don’t try to use small drillls like this in a Dremel, you will just break them or melt the workpiece.
                          • 18894
                          Just had a quick look around, the eclipse 120 pin vice set on Amazon looks excellent value. Remember, these can also be used for holding wire for shaping and filing if you need to, they don’t just hold drills....
                          • Bortig the Viking
                            • Mar 2019
                            • 780
                            Hi, thanks all for the help
                              • 18266
                              John , you had some bits in a set that had from 0.5 to 3mm I think, but the end that goes in the pin vice where all the same size. Made them a lot easier to handle and changing sizes very quick and easy. I even use them without the vice at times. will you be getting them again?
                              Sorry for the hijack of the thread Mark.
