If i were to try and incorporate some fibre optic lights into a 1/72 model kit (probably four lights at most). What equipment would i need to get to install the fibre and run it. And how easy is the fibre optic to work with?
Fibre Optics in a model
HI AL F/O is very easy to work with I have fitted it in planes for nav lights all you need is to make a small hole at the wing tips an elsewhere if usin 1mm f/o an glue it in place but no ninety degree turns with it only gentle curves back to a white bulb an then usein tamayia colour clear paints the end nr the bulb the coulour you want to show
chrisComment
Similar question asked here about LED's, might be a place to start as you'll need some kind of light source to run the FO :smiling3:Comment
I’ve done this before, but it’s a bit awkward to post about it now. Will do so tomorrow morning.Comment
