Fibre Optics in a model
  • spanner570
    • 15402
    #16
    Originally posted by AlanG
    It would only be turned on once in a blue moon lol
    Al', off subject a bit , this sounds like my missus!
      It’s now tomorrow morning, and I’ve found the thing I wanted to post:
      As some of you may remember, a long, long time ago I started converting a standard Land Raider into a Prometheus. I always had the intention that it would become a light-and-sound show as well — so here's a short, illustrated guide on how to turn it into just that ^_^ Front Deck The Prometheus do...
      That’s a thread I posted in 2008 on a Warhammer 40,000 forum about a Land Raider I had equipped with a light-and-sound show: an MP3 player with speakers, plus blinking and continually on LEDs, the former lighting up the exterior through fibre-optics. (Note that I had to disable my adblocker to get that site to load images.)
      [ATTACH]353200[/ATTACH]
      Check the thread for a thorough description, but the basics of it are that I bought some blinking LEDs and soldered them together with some resistors (again, see the thread for how to calculate what you need) into this circuit:
      [ATTACH]353201[/ATTACH]
      You can ignore the bit on the left with the MP3 player and amplifier, of course. It all looks like this in the flesh:
      [ATTACH]353202[/ATTACH]
      For the fibre-optics themselves, I used a cheap TOSLINK cable I bought at an electrics store:
      [ATTACH]353203[/ATTACH]
      On the left is the normal plug that’s at both ends of the cable, on the right is a piece I cut off and stripped. Initially I wanted to leave the black covering on it, but decided to remove it because it made the cable much thicker and less flexible. Inside the model, I put everything together like this:
      [ATTACH]353204[/ATTACH]
      I drilled holes into the sides of bits of plastic tube and glued them into the model, then inserted the fibre-optics. The LEDs sit inside the pieces of tube:
      [ATTACH]353205[/ATTACH]
      Here’s the model with the power off and on:
      [ATTACH]353206[/ATTACH]
      [ATTACH]353207[/ATTACH]
      The fibre-optics stick out from the side of the model so that I could paint the vehicle without having to mask 1 mm diameter lights: I just painted right over them and when I was done, trimmed the fibre-optics back to sit flush with the sides of the model.
