Best masking tape.
  • outrunner
    • Apr 2019
    • 2420
    Best masking tape.
    I am sure this has been asked many times before, but what is the best masking tape to use where there are a couple of 90 degree curves to go around? I could possibly brush paint the parts instead of masking, but with my brush skills I think it would be best to mask the area.
    Andy.
  • adt70hk
    • Sep 2019
    • 10409
    Andy
    I know Tamiya do a curvy/bendy tape. I have some bit have not used it yet. My version is white.
    Sorry I can't be of much more help.
      • 15696
      Hi Andy
      I have always used Tamiya tape and found it good stuff. Tamiya do a tape for curves. It is a kind of white, plastic stuff that will go round curves though I doubt it would go round sharp bends. It comes in 2mm, 3mm and 5mm widths. Here I used it for the curve and filled in with ordinary Tamiya tape.
        90 degree curves how? As in: you want to mask up a panel and then up and over onto the roof? Pretty much any masking tape should be able to do that, I would think. Or do you mean you want to mask a right-angle curve on a single panel?
        • outrunner
          • Apr 2019
          • 2420
          Sorry, I should have said in the question it is a right angle curve on a single panel each side.
          Andy.
            I'd second Jim with Tamiyas tape for curves. If you can get it, 3m blue fine line tape is similar but slightly better in my opinion, having used both.
            The thinner the tape the tighter curves it can do, but the more filling in with other tape you'll need, so bare that in mind when choosing. Personally I'd go for the thinnest.
              In that case, an alternative to narrow tape is to cut the curve from a larger piece of tape before putting it onto the model, then adding more tape to continue the straight edges.
              • AlanG
                • 6296
                You can also get painters pin tape. Goes around curves really lovely
                  Found the best tapes for both release & for flexibility are plastic.
                  I use Tamiya plastic tape & also car lining tape. All can be stretched around
                  a curve better than any of the paper tapes.
                  An advantage of plastic tapes they are not prone to wetting on the edge
                  as are paper tapes which leads to leaching of paint under the tape.
                  On any tape recommend cutting a new leading edge. All tapes tend to have
                  the adhesive slightly creep on the edge. Plus the machines cutting the rolls we
                  use from very large lengths are not all that good. A cut with a Morton blade
                  gives a pristine edge.
                  The car lining tapes.
                  Finespray Fine line Green Tape 6mm * 55m. Great for very straight lines. Only need
                  one width of tape if you cut a pristine edge to the width required.
                  3Mโ„ข Fine Line Masking Tape Blue - 6mm x 32.9m Brilliant for stretching around
                  acute corners. Cut this down to just one millimeter in width to get around a very
                  acute bend.
                  Only need one width of tape on both the above if you cut a pristine edge to the
                  width required. A roll of each will last a life time.
                  I have not had any paint leaching under with these two tapes. No need to mitre
                  or butt joints just over lap & bed down on the overlap. Use gently the back edge
                  of a Morton blade or similar to push down tape into panel lines & on the overlaps
                  • rtfoe
                    • 9084
                    Laurie's got it right especially the cutting for that clean edge. From a single one inch thick tape I would tape a suitable length on a piece of glass and slice thin strips about one to two mm and work with sharp nosed tweezers when applying on canopies. I try not to use the pieces with the side ends of the tape as they would likely have dust or fibres. Lock one end of the tape onto the surface and teese the tape round corners with the tweezer. You'll never get anything done with fingers for tight corners unless you're a Liliputian.
                      • 15696
                      Laurie and Richard
                      That idea of cutting a clean edge to avoid dust, dirt and glue is one I'll remember - thanks :thumb2:
                        And avoid putting your roll of tape down on the bench or just slinging it in a drawer. Keep it in a bag or dispenser so that the exposed glue on the edge of the tape doesn't pick up contaminants.
                          I use a DVD disc to cut tape & also PE frets.
                          Does not slip (PE) plus it is kind to Mortons.
                          Also use the American Razor which is much finer than a Morton blade.
                          Also use the American Razor for cutting PE from the fret. So fine that
                          in most cases you do not have to file off that rough bit. Cheap as chips
                          & you have two edges on each blade.
                          PS. Good idea to just tape one end temporarily. Saves on blood. :smiling6:
                          Another thing that I have picked up with in the disaster experience area.
                          Keep the amount of tape in contact with paint to a minimum. Just use
                          enough thickness of tape to mask then use tracing paper or similar to
                          stick over the masking tape. Then there is the minimum likelihood of
                          paint stripping .
                          B & Q market a very thin foam roll which is used under hard flooring.
                          Perfect for filling in masked areas. Easily cut or torn paint proof & also
                          forms easily to rounded surfaces. From memory about ยฃ10 per roll.
