Hi, can anyone tell me if I need to be aware of anything regarding soldering. My big locomotive, which consists of all materials, needs some soldering during the build and then some painting, I'm assuming prime then paint, but want to check this is right before I do it. It's going to be a big old thing, 49cm but looks interesting learning new skills as its metal and wood plus some obligatory plastic. Here's hoping I can do it justice.
Soldering
Tags: None
I'm sure there are guys who can help you. for me, soldering is a dark art I have never mastered. good luck.
peterComment
Just been watching James May reassemble a portable record player. He says you need three hands to solder properly.Comment
... and don't burn yourselfoop:
I used to solder a lot of electronics, I blew very subtle when adding solder to avoid being with my head into the fumes.
And don't 'move' things the first seconds when the solder is cooling down, that gives a 'matt' finish (means less strong connection)
Goodluck :thumb2:Comment
Mark, what are you soldering? Soft soldering or silver soldering? I assume soft soldering, using a tin-based solder - it used to be about 60%tin, 40% lead, but now lead is known to be dangerous there are other metals used to replace it now.
The first thing is that the surfaces to be joined must be clean bright metal, no fingerprints or grease. Second, remember that the workpiece should melt the solder, don't just blob the solder on with the iron. Ideally you want the pieces to be held together before you solder them - this might be by taping them to a tile or just putting weights on them, again on a heat-proof backing such as a tile. Keep the tip of the iron clean. Not sure what else to say really!
PeteComment
Hi Mark
have a look at the Carr’s products now owned by Phoenix Paints. There are many ways to approach this but I would recommend 145 solder with liquid flux. Don’t try and use electrical solder, you’ll drive yourself mad.....
also, before priming scrub the model with meths to remove solder flux residue.Comment
Thanks guys, boy is this model going to be fun, its soft solder I'm going to do, I think patience is going to be key.Comment
One other hint...
if you drop the iron, don’t try to catch it.....been there, done that, and it really hurts.....Comment
Hello Mark,
Lots of good advice given above.
I use a variable temperature electric iron and low temp solder. things to remember is jig up the parts if you can, I solder on a thick smooth kitchen floor tile, that allows me to draw angles if I need to and I have also secured two 6 inch metal rules held down with double sided carpet tape as a permanent 90 degree.
I also use a torch and Carrs solder paste which you can brush on or apply with a tooth pick depending on the area to be covered.
The other item is have a look on you tube at a guy called Plasmo, he does a tutorial just for beginners, and there is not the usual 24 hours of waffle before hand, you should be able to pick up a lot from him.
Do not be worried, get some old brass etch and use the video above and get some practice in before commiting to the real job.
[ATTACH=CONFIG]n[/ATTACH]
All of the etch brass bar armour on this Leopard was soldered with a torch and solder paste using the toothpic method, and was the first time I had used a torch.
Hope this helps,
Mike.Comment
