How much glue do you use chaps??
  • BattleshipBob
    • 6792
    • Bob
    • Cardiff
    #31
    No you are not Bob. The only glue that sticks the parts is that found between them. Anything else just wrecks the surface and appearance. You can’t hide it with paint! If I end up with excess glue outside the joint I let it set hard then scrape it down to get rid of it.
    Thats what i was thinking Tim, watched another YT build and again he slapped it on, no sign of any cleaning up.
    • boatman
      • Nov 2018
      • 14455
      • christopher
      • NORFOLK UK
      #32
      WELL Bob i know im scratch building an its not a proper part like in a kit but when i use my glue or c/a on my tube ive got a very thin lead out tube thats about a half a m/m so only the edges get glue an not go every where but if that does happen then i just wipe it clean an if its gone hard then i just use a mini flat needle file to file off the glue then usein a very fine sandpaper then smooth it off hows that
      chris
      • BattleshipBob
        • 6792
        • Bob
        • Cardiff
        #33
        chris
        Sound advice Chris, thanks
        • Si Benson
          • 3572
          #34
          Have you tried a test piece Bob? Take a piece of plastic card, smear too much glue on half of it and leave the other side plain.
          let it dry then just spray it....see if you can see a difference under paint :thinking:
            • 18901
            Just had another think about this....which glue do you mean Bob? Liquid glues, like EVA or Mek Pak, won’t leave a stain. They wick under the join by capillary action, melting both faces to make the join. Any left on the surface will simply evaporate. Glues like Contacta have a solvent in a carrier and will leave the carrier as a residue when the glue evaporates.
            • JR
              • May 2015
              • 18273
              #36
              I tried to use as little as required, but then ended up with too little. Sometimes I leave finger prints on the part I've used too much on, ending up spending more time cleaning.
              Agree with Tim about what happens with using too much CA, the pe will or plastic will just not glue.
              As to activator I now make my own, 26 ml of IPA to one 1/4 tsp of Baking Powder, stir well and add to a small spritz bottle , works well .
              • wotan
                • May 2018
                • 1150
                #37
                So for some people SWMBO let's you put stuff in the fridge...! WOW.
                I'm of the you can never have too much glue school.
