Window with ugly joint in the Middle
  • Supabuild
    • Jan 2020
    • 29
    Hi Folks, I'm building an ACADEMY MINICRAFT B17-G 1/72 scale.
    The back section where the rear gunner sits, has an ugly seam running right down the middle of the window.(Cheyenne Tail section)
    I've had this model in the cupboard for over 22 years and decided recently to build it, so, its a bit of a vintage.
    Does anybody have any ideas as to how I can get rid or reduce the presence of this ugly seam on this section of the plastic clear part.
    If you guys want, I can post a picture of what I am going on about if it helps.........Thanks a lot
  • Mini Me
    • Jun 2018
    • 10711
    That would be helpful.
    • AlanG
      • 6296
      Have you got a few different grades of sanding sticks/micromesh?
        • 15687
        Hi John
        A ridge down the centre of a clear canopy. Like this ....
        Scrape the seam down with a sharp blade and then polish the canopy with very fine sanding/polishing sticks or cloths. I prefer to use Tamiya Polishing Compound - comes in Coarse, Fine and Finish. The canopy can then be dipped in Klear for extra sparkle but that is not essential.
        This is the same canopy after scraping and polishing .....
        Tamiya Polishing Compound is not easy to find and is quite expensive but will last for ages. I use it on a cotton bud.
        • AlanG
          • 6296
          If you want a cheaper option to the Tamiya compound..... toothpaste
          • Mr Bowcat
            SMF OG
            • Dec 2016
            • 4600
            • Bob
            • London
            Yep, scrape and polish is the way to go.
            Si vis pacem, para bellum.
              I was just about to say that or Autosol metal polish, use with card first and then polish with tissue and when happy wash in soapy water to get rid of any excess left and then dip in a cup of Kleer and let dry.
              Mike.
                Also: you may want to practice on a spare part first — or the mould part line on the side of the sprue if you don’t have any suitable spare parts.
                • Supabuild
                  • Jan 2020
                  • 29
                  I want to buy some for this,can you recommend any for me please?
                  • Supabuild
                    • Jan 2020
                    • 29
                    Originally posted by Jim R
                    Hi John
                    [ATTACH=CONFIG]n1114076[/ATTACH]
                    [ATTACH=CONFIG]n1114077[/ATTACH]
                    Man that looks great. Your method of achieving this would be greatly appreciated. Thanks a lot
                    • Supabuild
                      • Jan 2020
                      • 29
                      Here are a few photos of the problem clear part with the join right in the middle.
