Cleaning Clear Parts.
  • JR
    • May 2015
    • 18273
    Hi all .
    On the BM truck I managed to get some clear glue on the screen part. Also there are a few scratches
    I seem to remember there as something used to polish it .
    Can anyone help please .
    Off to battle with those Masterclub tracks !
    • 15681
    Hi John
    This recent thread may help. You can polish out the scratches but you may have to gently scrape off the glue and then polish the area.
    • Allen Dewire
      • 4741
      • Allen
      • Bamberg
      Hi Dude 2,
      I think Jim forgot to post the link to the thread….
      If the glue is dry and is not an aggressive type, you could gently scape it off with a toothpick or other wooden piece. If you get it off the clear part, you can polish it out with plain old toothpaste. It will fill the scratches and then you could try dipping it in Klear to bring back the shine.
      Another idea is, depending where the spill is, dirty up the wind shield and only have the area covered by the windscreen wipers clean. This means cutting out some tape to mask where the wipers would wipe and then spraying or brushing dirt color or pigments on the rest of it. After it's all dry, gently peel off the tape and 'Voila'...…………..HTHs
        John,
        I use jewellers' rouge - a very fine dust-like grit, mixed with washing up liquid. ( having removed any surplus glue by shaving, or scraping ). It takes quite a while, but it will remove the mark, then dip in Kleer, and that's it. As Allen says, toothpaste also works well!
        Sometimes it's better to do the whole window ( rather than part ), as you can end up with a slightly different texture!
        ps now that you've mastered the PE problem - Isn't it time you faced the individual plastic track link bogey?
          • 15681
          Sorry John
          Blame it on senility and Storm Dennis :rolling:
          HERE it is but Allen and Dave have some sound ideas.
          • JR
            • May 2015
            • 18273
            Originally posted by Jim R
            Hi John
            Thanks Jim, but hiding the link because I 'm not in the TBC is most unfair. :nerd:.
            Hi Dude 2,
            Dude 1 , great idea, think I have some windscreen wipers, that might do the trick. The frustrating thing is one of the windows doesn't fir very well Will have a go at cleaning the edge.
            John,
            Thanks Dave.Unfortunately I don't have any Kleer , however I soaked the offending part in IPA last night and a lot of the glue came straight of. With the rouge in mind I'm going to try the toothpaste. As there will be snow I might be able to hide the bad fit.
            Now these tracks in plastic !!!!! might one day have another go .:sad:
            Sorry John
            Jim I blame the wind ! Great tip, going to use the toothpaste and let the snow cover the rest. White mud !! :smiling2:
            Thanks guys for the help, appreciated .
            John.
